lrp 7,5 verctor x11 ---->
is it too weak for a bj4we,im running on a small ,tight indoor track. my speed is a lrp sphere tc with a maxxamp 5500...our stretch is not really long...70 feet maybe a bit more or less..so...im just not sure witch one between 5,5 6,5 or 7,5...6,5 are B-O so 5,5 or 7,5?? thx....dont need something too crazy you know..you win race on 4 wheels not on 2!! thx
7.5 should be more than ample, it will get you out of corners a lot quicker because you will be actually putting the power down.
Have a look at the worlds recently held in Japan and a lot of the drivers were running 7.5 equivalents
have a look at getting the optional sintered rotor and fitting it to your 7.5, you will notice a massive performance increase!
what gearing are you running? I would look at running something like 17/81 or 16/78 (for standard 7.5 with bonded rotor)
if you put the sintered in, gear up 2 teeth on my recomendation
I run on a small track with a 60 foot straight (indoor). I have been running the VEctor 6.5--with sintered rotor in my BJ4 WE. I think its just about perfect for the track size. Its worth getting the sintered rotor--better brakes and a bit more low end torque with similar top end. 7.5 would be a good choice as well. Many of the guys in 4wd run Orion or NOvak 7.5 motors.
I run a non sintered 6.5 with LiPo on a track about that size. It's a little too much. I will be dropping to a 7.5 when I get the chance.
