Old 01-08-2008, 04:07 PM   #1
Send a message via AIM to ThunderRobo Send a message via MSN to ThunderRobo
Default ZX5 Electronics placement
haha...
I cant seem to get get everything in this dang car!
would some of you guys please share what your setups look like?
i am running...
Reedy/LRP Neo One 3.5T
Novak GTB w/ low-profile fan
Futaba 9550 servo
and transponder...
I think i have to cut a hole for GTB either way, but what about the RX? i can only get it to sit on it's side, and when i do that, i cant get the body fully on
Derek.C
http://www.runryder.com/helicopter/gallery/43404/
ThunderRobo is offline   Reply With Quote
Old 01-08-2008, 04:13 PM   #2
RodneyB's Avatar
I'm currently running the GTB w/o the fan (at least here in the winter) and have had no problems. That allows me to push it into the center as much as possible. When I was running the fan I cut the body 1/4" higher than normal.
I have my receiver on the top plate between the antenna mount and the front windshield. The ponder I have on the top plate behind the front shock tower. Fit's no problem.
RodneyB is offline   Reply With Quote
Old 01-08-2008, 04:20 PM   #3
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
look within the last 4 pages of the kyosho electric off road thread. I just did it. My car is white you will see my wiring pics. Just gotta be creative and patient.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-08-2008, 04:24 PM   #4
http://www.rctech.net/forum/showthre...85386&page=150
Old 01-08-2008, 05:09 PM   #5
thanks RodneyB and RB5!
Derek.C
Old 01-09-2008, 05:38 AM   #6
The stock body is really tight for space .....
Try the Balkan (LAB03) or Bullet (LAB02) bodies .... a fair bit of space under them.
http://model-car-racer.co.uk/
Today AE .. tomorrow who knows?
RogerM is offline   Reply With Quote
Old 01-09-2008, 07:15 AM   #7
Djioul's Avatar
I've just put my novak gtb with fan on the top plate at the "driver place" and I cut a hole in the body to allow the fan to "breathe".
It's not perfect regarding the high position of the weight but haven't been able to fit it lower with the standard body.
Djioul is offline   Reply With Quote
Old 01-09-2008, 07:28 AM   #8
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
Before you trim your body sides, check to see if you need extra clearance and leave a little extra for fan clearance. The balkan looks like its got more clearance also than the bullet.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
Old 01-09-2008, 12:56 PM   #9
Trader Rating: 52 (98%+)
I cut my body higher, almost no cut at all on the side, and I use velcro to attach the body to the chassis.
I don't use fan becasue the fan blade breaks easy. They costs $18 each to replace.
I have no problem running 6.5. It is planty fast. I drill some holes on top of the gtb for airflow and a few holes in front.
Lots of RC Stuff
straightaway is offline   Reply With Quote
Old 01-10-2008, 05:10 AM   #10
Djioul's Avatar
My GTB/6.5 with the fan was clearly overheating with the stock pinion (not a surprise, I know...) so I prefer to keep the fan so far.
Maybre I should try without once, now that I have a proper gearing, with a small air intake on the body...
Old 01-10-2008, 06:07 AM   #11
Racerx336's Avatar
Trader Rating: 34 (100%+)
I run a sphere and a 6.5. I turn the sphere on it's side and have a flap cut out and bent on the body so that the sphere can protrude ever so slightly, but the body is still covering it. No overheating problems here either. I will have to get pics.
Racerx336 is offline   Reply With Quote
Old 01-10-2008, 07:33 AM   #12
everything underneath nice and snug. That gtb looks massive, my sphere fits great.
Old 01-10-2008, 07:54 AM   #13
Djioul's Avatar
It's especially massive with the fan, without it, it will fit without problem under the body.
Electronic Placement? Associated-08 Electric Off-Road 0 03-04-2008 09:12 PM
Schottky diode placement? aus jd 2703 Electric On-Road 5 09-12-2006 07:48 AM
Personal Transponder placement lookinco Electric On-Road 3 01-28-2006 06:17 AM
Inline Battery placement, so why not? Ginsu Electric On-Road 42 02-01-2005 07:52 PM
esc and rx placement in micro rs4 SunRunner Electric On-Road 0 09-27-2002 09:37 AM
