Old 02-24-2008, 10:13 AM   #46
Send a message via AIM to David Alberico Send a message via Yahoo to David Alberico
I had a bad cell in one of my packs and it caused my 570 to stutter. Though I'm sure it was my pack at the time, I do recommend the latest software.
Castle Creations, J-Concepts, WMD Products, Clints Creations
David Alberico is offline   Reply With Quote
Old 02-24-2008, 11:09 AM   #47
MikeL.'s Avatar
I would take a look at your batteries, bad batteries are probably the number one cause of stuttering in our systems. The software you are running should be fine. I ran the beta version for over a month before we released it to the public and never experienced a single cogging issue. Check your batteries first and if that doesn't fix it, then try hardwiring your motor wires. Good chance one of these things is whats causing your issue. Wouldnt hurt to update your software when you get a chance, but it shouldnt cause you any issues if you are unable to do it.
MikeL. is offline   Reply With Quote
Old 02-24-2008, 11:51 AM   #48
Trader Rating: 23 (93%+)
mine was real slow and would stutter bad. i was using a brand new pack of 3000's a cheap pack that i got for my kids truck and. i tired a differnt pack and problem was fixed. they are picky on batterys
afish is offline   Reply With Quote
Old 02-24-2008, 12:25 PM   #49
Okay, I got it working... it was the radio/receiver. I switched it with my son's Traxxas Rustler radio and it works great. We put the Futaba in his and it works just as well. So, until we can upgrade to a 2.4ghz, we'll have this setup.
All of you, thank you for your help and the advice. I am really pleased right now. We're charging our batteries and getting ready to head to the track. We'll see how much stuff I will break today. The next thing I need to figure out is the wheelie problem! How cow, even with the 12T it's super fast and the low end is unbelievable. I'm going to have to adjust everything a little slower again. :-) I can't believe I just said that. Time to go drive the Ferrari through the neighborhood at full speed!
Hans
windsurf17 is offline   Reply With Quote
Old 02-24-2008, 12:27 PM   #50
BTW, 14 hours and 8 replies and problem solved... thanks a ton. RCtech is great.
Old 02-24-2008, 12:43 PM   #51
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
good to hear, enjoy it.
R
UltegraSTI is offline   Reply With Quote
Old 02-24-2008, 05:34 PM   #52
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Glad you have it working. Now have a good time.
ST Racing Concepts (STRC)
Old 02-24-2008, 06:11 PM   #53
...we did :-)
Old 04-18-2008, 03:21 AM   #54
deRRo's Avatar
Send a message via MSN to deRRo
BUMPP!!!
Regards
Adam
deRRo is offline   Reply With Quote
Old 10-16-2008, 10:57 PM   #55
SN33KY's Avatar
SN33KY is offline   Reply With Quote
Old 10-18-2008, 05:05 AM   #56
PapaJay's Avatar
I have use my mamba max for 3 month or so,
Today I hook the mamba with my laptop, the red and pale green leds was bleeping, no sound of beep or anything.
everything its ok, I can change settings and updates on it.
as I remember it play some tone when it connected with pc.
Can someone clarify that mamba does play sounds when hook up with castle link?
PapaJay is offline   Reply With Quote
Old 10-18-2008, 07:37 AM   #57
My Maxx only sounds tones when powered by battery to let you know it's initializing. Does not make a sound when connected via USB to PC. I would say it is working perfect. Have fun!
JLinney is offline   Reply With Quote
Old 10-18-2008, 08:07 AM   #58
PapaJay's Avatar
Great, thanks.
I have a crash 3 weeks ago ended with busted servo, the esc was release from the straps and slammed inside the body.
hohoho tough esc.
Old 10-18-2008, 08:15 AM   #59
Dadx2mj's Avatar
My son and I both have been running a Mamba Max system for about 1.5 yrs. In that thime we have had to return 3 ESC for repair or replacement. One was totally due to human error the other two just failed. Castle replaced hem all. The first two were replaced in reasonable time the last one really had me upset. It took over two months to get replaced. The issues with the Monster Mamba Max really screwed up Castle.
BlindManRacing
Powered by Mamba 5700
Dadx2mj is offline   Reply With Quote
Old 10-18-2008, 09:16 AM   #60
dangerwr's Avatar
I have to say that I have not been all that impressed with the Mamba Max that I own. However, as I read these forums I gathered more people have had good experiences than bad.
I use Novak's brushless on my Superten. When I bought a T4 it seemed as if the majority of the guys were using Castle in the off-roads. When I received my MM it would not connect to the Castle link. I decided to install it and just run with it--almost immediately it came apart.
I will not bore you with all the over heating issues for those are probably my fault. The last time the ESC came apart it was to my surprise that one of the components on the PCB had a broken lead. I just super glued the stupid thing back together and amazingly it worked .
Castle's Mamba Max is a bit cheaper than the leading competition and obviously honor their warranty. I wonder if they are making money off these things. I do not believe the quality is there but they are not charging for it either.
Losi 8ight 2.0 EP - MMM & Tekin 1900Kv
Losi 8ight-T 2.0 EP - MMM & Tekin 1550Kv
Durango DEX410 - Orion R10 Pro & 8.5T
TLR 22 - Orion R10 Pro & 13.5T
dangerwr is offline   Reply With Quote
Mamba Micro Pro, mamba 8000kv, Spektrum 3001 rx, heat sink pinoyboy R/C Items: For Sale/Trade 3 05-13-2008 06:19 PM
Mamba 4200 + Mamba 25 Shawner85 R/C Items: For Sale/Trade 0 01-30-2008 05:54 PM
Mamba 5400 with mamba 25 esc for sale josh the 2nd R/C Items: For Sale/Trade 4 01-14-2007 04:11 PM
MAMBA COMPETITION X 2080 and data cable / mamba 6800kv with esc tmaxxking R/C Items: For Sale/Trade 11 05-23-2006 10:59 AM
Mamba 8000/Mamba 25 esc coolkide R/C Items: For Sale/Trade 11 12-23-2004 05:48 PM
