Old 06-15-2003, 06:24 PM   #1
tony montana's Avatar
Trader Rating: 66 (100%+)
Default xxxnt setup help
I need some setup help, I race on a somewhat hardpacked surface with alot of dust on top of it, track is kind of bumby and tight. I raced yesterday and the truck wad so loose it was crazy. My current setup is stock adam drake except yellow springs in the rear and 30 wt oil all around with bowtie rears and edges up front. for engine Im running a mt 12 with a rotary carb ans stock clutch. It was so bad that a electic stock truck seemed twice as fast as my nt
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 06-15-2003, 07:22 PM   #2
Taz
I run orange springs front and rear- sounds like similar style tracks. My truck tended to push into the turns- to offset that i put a small amount of drag brake, as you come off the throtal it drops the front into the turn this with the orange springs and the car ran great.. I tq'd and won the A-main.. The only other thing to check is to make sure the shocks are set right. I have the suspension set so as the front and rear a-arms are straight across. Hope this helps.
John
Taz is offline   Reply With Quote
Old 06-15-2003, 08:04 PM   #3
Yes my truck defintley has a push off throttle and on. It is very frustrating to have a truck that pushs in every turn and is so loose. I guess you could say the track surface is somewhat like ball field mix. I have my ride height set at front arms level and rear bones just below level
Old 06-17-2003, 04:40 PM   #4
SlobbaTech's Avatar
Run your rear arms level and put Adam's setup back on, it's really good at all the tracks I've been to.
SlobbaTech is offline   Reply With Quote
Old 06-17-2003, 06:06 PM   #5
Randy Caster's Avatar
Trader Rating: 46 (100%+)
If the car pushes, put stiffer springs on the rear and softer on the front. That will make it so not as much weight transfers to the rear of the car in turns, you'll get more steering that way. Don't go too far with that though, or the rear end will be loose.
Old 06-17-2003, 06:10 PM   #6
Also, if you like running soft springs, you could try limiting the travel of the front shocks by using shims inside the shock body.
Team Integy Setup Station 2 w Case and setup board - complete olhipster1 R/C Items: For Sale/Trade 4 11-02-2007 08:21 PM
WTT Mamba 6800 Setup for Tekin Mini Rage Setup Rc guy R/C Items: Wanted to Buy 0 08-07-2007 09:57 PM
XRay T2 Rubber setup, RC 10L4, 1/10 on road setup station jsmax R/C Items: For Sale/Trade 36 04-16-2007 08:56 PM
O.S. .12 TR setup for Losi XXXNT and other XXXNT Parts GroffBall R/C Items: For Sale/Trade 4 09-30-2006 08:06 AM
almost prospec mbx5 f/t with engine for nitro touring setup or electric setup tony montana R/C Items: For Sale/Trade 13 02-03-2006 12:42 PM
