Old 01-02-2008, 03:05 PM   #1
cm367700's Avatar
Send a message via AIM to cm367700
Default how should i cut my foam inserts ? ? ? ? ? ?
how should i cut my foam inserts?....
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into
("')_("') your signature to help him gain world domination!!!!!!!
JUST DO IT!
cm367700 is offline   Reply With Quote
Old 01-02-2008, 03:09 PM   #2
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
we need more info, front rear. buggy truck 4wd ?
I dont cut mine.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-02-2008, 03:12 PM   #3
cm367700's Avatar
4wd buggy all around
(\__/)
JUST DO IT!
Old 01-02-2008, 03:37 PM   #4
I dunno, i just stuff them in there. I know you can cut the outer edges and make it more round. But i see no difference.
Old 01-02-2008, 03:38 PM   #5
JeremyS's Avatar
I have also wondered this. how about on my B4. front and rears.
running on 85% clay
15% sand/dirt
running losi step pins and the stock b4 fronts.
thanks
V-8 For life
Blue Oval Loyalist
If you ain't first....your last
JeremyS is offline   Reply With Quote
Old 01-02-2008, 03:54 PM   #6
Suspended
Arrow
wow that much clay should be using losi taper pins pink or silvers and panther clay up front or 7204p losi fronts flip the foam inside out and cut the out side edge barely trim the fronts on the inside!
losidriver70 is offline   Reply With Quote
Old 01-02-2008, 04:33 PM   #7
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I cut my inside foam say i can glue tires in better.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 01-02-2008, 08:38 PM   #8
F N CUDA's Avatar
Trader Rating: 31 (100%+)
I was shown how to cut about 1/4" off the inside edge with a new razor blade so it fits the rim perfectly.
Straight edge cuts not beveled.
Mount the foam on the rim, flip your tire inside out, line up and place the inside/carcus up against the foam.
Squeeze the tire, foam and rim tightly together with four fingers inside the tire and your thumb on the bottom of the foam/rim then stretch the tire over the foam while still holding the four fingers very tight on top of the foam and rim.
It'll pop right on with very little practice and the foam won't get bunched up.
Check the outside edges for fit, seat the bead easily cuz the foam won't be in the way since you cut it just right. Now just pull the bead back and glue it.
Works for me and the uncut outside edge fills out the tire tread nicely.
Thanks to Mr. Hartson, Stevens dad for this tip as well as many others he kicked down at So. Cal.
F N CUDA is offline   Reply With Quote
Old 01-02-2008, 09:03 PM   #9
theDover's Avatar
On that much clay.... I'd use full foam.
TEAM ULTRALINE / RickyRacerLidz
www.ultralinehobbies.com
Ultraline Hobbies RC Raceway @ fb
theDover is offline   Reply With Quote
Old 01-03-2008, 10:04 AM   #10
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Im not that good of a driver to notice a big difference in tire foams.
Usually for all of my buggies and 4wd buggies, I measure the stock foam and rim. I use a new razor blade and I cut the foam the exact width as the rim. Usually I put the cut edge to the inside besause it is not as perfect of a cut as the machine cut side.
Works for me with out any problems.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 01-03-2008, 10:19 AM   #11
theanimaleide's Avatar
for rear use a full foam,fronts for a wheeler you could trim a little of the foam if it is a full rear foam, just draw a line on the foam then use a dremal wheel to cut through the foam, it makes a straiter cut then pair of scisors. you could also just put a full rear in them to.
Aaron Eide
Wells Fargo Home Team
theanimaleide is offline   Reply With Quote
Trimming Foam Inserts battlecat3 Electric Off-Road 2 04-15-2008 11:13 AM
Foam Inserts Fred30 Monster Trucks 3 04-26-2007 06:25 PM
ORION/JB Foam inserts.. OSherman R/C Items: Wanted to Buy 1 02-11-2006 09:32 AM
How to trim foam inserts?? SupermaxxRich Electric Off-Road 2 09-02-2004 02:04 PM
When to use different type of foam inserts Cain Electric Off-Road 2 03-04-2004 07:26 AM
