Old 01-02-2008, 12:47 PM   #16
MikeXray's Avatar
Trader Rating: 73 (100%+)
Are you using the inside or outside hole? looks the the inside should take a bit more of a hit, I would also put a washer on both sides.
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 01-02-2008, 01:20 PM   #17
MOmo's Avatar
I've broken 2 front top plates on my BJ4WE. Its $30 for a replacement.
Working on a replacement option.
MOmo
RACE CARS: B44.1, RC8.2E FT, RC8TE ME, YZ-2T, D08
RADIO: Futaba 4PKS/3PKS. BATTERY: Venom
ESC: SpeedPassion. MOTORS: SpeedPassion / Venom
"Im not a racer, but I play one on the Internet"
MOmo is offline   Reply With Quote
Old 01-02-2008, 01:24 PM   #18
Doodad's Avatar
Send a message via Yahoo to Doodad
Maybe try putting set screws in the unused holes for a little extra support. And for gods sake seal the edges.
Doodad is offline   Reply With Quote
Old 01-02-2008, 01:38 PM   #19
Can you explain to me how set screw in the unused holes are going to add support? In my tiny little mind it seems like it would actually put more stress on the top plate over having them empty.
Also, I believe in putting CA on the edges of CF parts to keep the layers from fraying under contact with other objects, but I didn't realize it actually added strength to the car. Can you explain that one as well?
glitchy is offline   Reply With Quote
Old 01-02-2008, 02:06 PM   #20
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
^^ Im not to sure about the set screw idea but as far as sealing the edges go, the CF absorbs a fair amount of the CA, and stops the CF from fraying and being easily chipped like is what happens when a ball stud pulls out of the side of the hole, have a look if you ever break it there and see how the CF looks.
If it is only the holes that are breaking out, try using some really wide footprint #4 washers, preferably steel ones, use one each side of the CF deck on the ball stud, this will clamp the CF into it like a vise, and stop it from being as easily broken as there isnt a great deal of surface area around those holes.
NJA82 is offline   Reply With Quote
Old 01-02-2008, 02:16 PM   #21
Doodad's Avatar
Holy wow Popeye! Didn't mean to insult anyones intelligence, but take it however you want....I've yet to see a pic of exactly how these pieces are breaking. If the ball stud is being ripped out and making the holes unusable, the set screws would help. You don't think a solid piece of CF is stronger than the same piece w/ holes in it? Same concept. People have been doing it in on road for years. As for gluing, should be a given with any CF part. Ease up tough guy. Just a suggestion.
Old 01-02-2008, 02:27 PM   #22
Trader Rating: 38 (100%+)
The ones I've seen broken had been using stock ball cups...
Originally Posted by RBMike View Post
How many of you who have broken the top plate have after market (RPM) ball cups on the car?? So far the only ones I've seen break have all had RPM ball cups. FYI, I made a brace by cutting up an old Mugen MBX5 rear shock tower. I'll post a pic later.
JQ Products "Le Car" - 3 of them. Primary, back-up, and spares car
Bunch of "classic" Schumachers
Tamiya - Leopard 2A6, Tiger 1
HPI - Blitz
bushyar15 is offline   Reply With Quote
Old 01-02-2008, 02:28 PM   #23
I'm just asking so that I can get an understanding of the physics of how this would improve the situation. To me a solid piece of CF and a piece with holes and set screws screwed into them seem vastly different, wouldn't the set screws apply tension on the CF that wouldn't be there otherwise?
Old 01-02-2008, 02:48 PM   #24
Doodad's Avatar
glitchy- Once again, I haven't seen a pic. But if the ball stud is ripping out, chances are it's happening between holes. The set screws MIGHT help to prevent this by providing support where there used to be nothing but open space. And it would be a cheap option. Can someone post a pic of their broken part please?
Old 01-02-2008, 02:53 PM   #25
Jason Pelletier's Avatar
They should make plastic ones, 20 bucks for a part that breaks alot can get pricey.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 01-02-2008, 03:00 PM   #26
And Doodad, I'm just asking for you to explain to me how putting a screw in a hole (when the screw doesn't attach to anything or anywhere) is going to give it strength since you posted the theory.
Most all of the parts I break seem to break where there's a screw. When arms break on my cars it's often through a hinge pin retaining screw (a screw that mostly fits the doesn't attach to anything or anywhere description). So, I'm just trying to understand why putting extra tension/pressure in an already fragile area is going to help under any circumstances.
Old 01-02-2008, 03:26 PM   #27
Doodad's Avatar
glitchy- OK. How much material is there from one hole to the next? Couple mil? That makes for a pretty weak area. When the ball stud rips out, if this is indeed what's happening, it usually happens because of the lack of material between holes. If the holes were an inch apart(not a feasible option) the chances of this happening are greatly reduced. That being said, putting a set screw in an adjoining hole prevents the ball stud from ripping through that mil or so between holes.
Old 01-02-2008, 03:32 PM   #28
And how is that? Does the set screw fuse and become one with the Carbon Fiber bringing it back to it's virgin undrilled state? Again, it seems to me like the set screw would put additional pressure (spreading) on the holes encouraging them to rip apart. If we were strictly talking about head on crushing, I'd buy it as the CF would have no room to collapse, but we're talking about cracking/splitting/snapping.
My problem is that I think you've suggested something that may make the problem worse instead of better, hence the reason I want you to provide a sensible explanation as to how it will really help instead of further compounding the issue...and before everyone tries it and snaps a bunch more $20 parts just cause they heard on R/C Tech they should do it that way.
Old 01-02-2008, 03:37 PM   #29
smac's Avatar
Don't Hit Stuff!!
Scott McDonald
VelocityRC/Scale Motorsports/Checkered Flag Hobbies/SmacTrac
smac is offline   Reply With Quote
Old 01-02-2008, 03:39 PM   #30
Doodad's Avatar
Originally Posted by glitchy View Post
And how is that? Does it fuse and become one with the Carbon Fiber bringing it back to it's virgin undrilled state?
edit: Seeing as you added to your post, allow me to rephrase. I said it MIGHT work. I said it in BIG LETTERS so people would see the emphasis on "might" and not take it as some miracle solution. I know that I've done this in problematic, high-stress areas on other vehicles before and it has worked. NOW I'm done with you.
T4 rear chassis plate EvolutionT4 Electric Off-Road 12 09-09-2008 03:33 PM
Mugen MBX5R rear end breaking loose, Help Pls! pracy Nitro Off-Road 14 05-20-2008 06:46 PM
Assocaited B3 Rear Rims, T3 Rear Chassis Plate, Front Chassis Brace Hawk6 R/C Items: For Sale/Trade 5 09-04-2007 07:34 AM
Breaking in Mugen MT12 rear/slide/SG coolrcdad Nitro On-Road 3 08-02-2002 08:12 AM
Hardcore chassis. top plate and rear for Micro rs4 (silver) Jeff Ford R/C Items: For Sale/Trade 2 03-27-2002 11:41 AM
