Old 12-28-2007, 04:37 PM   #1
Trader Rating: 69 (100%+)
Default Building T4 shocks...frustrating.
Okay I know im a noob, Ive only built a few kits in my lifetime.....but trying to build these FT T4 shocks is making me feel like a donkey. I have taken my time, trimmed, used green slime, the works. BUT when i get to the part where you fill the shock, then the cap, and then magically slap them together, they keep getting cross threaded. I dont think I have ruined the caps yet but I am not sure. I have to wash everthing and see what the damage is. I have tried it over and over again...calm and collected like three separate times with only LUCKILY get one successful shock complete. WHen I finally got one other on all the way it gushed oil out like the o-ring was damaged. I took the rings off to check to see if I tore one and they look intact. Why did Associated not include aluminum caps to match up with the aluminum shock bodies it would have really made life easy. These cheap plastic caps absolutely suck. None of them are going on smoothly. Am I doing something wrong. I was looking on ebay and found blue aluminum shock caps for $10, should I just go that route. I am sooooooo frustrated.
Paul Whalen is offline   Reply With Quote
Old 12-28-2007, 04:55 PM   #2
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
first time threading them is always weird, i thread backwards for a turn (CCW), then go the right way (CW) then they seem to work better.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 12-28-2007, 05:19 PM   #3
Yep tried that several times, I am gentle with it too. I just dont understand why I am having such a hard time. I think Im going to order those aluminum associated blue caps off ebay just to make things easier.
Old 12-28-2007, 05:54 PM   #4
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
I have built and rebuilt associated shocks over the past 15 or so years. They are a pain in the arse untill you get the hang of it. After you get the hange of it, it is still sometimes a pain in the arse.
I would buy the aluminum caps and call it a night.
Best advice I can give besides back threading them like Jake mentioned, and take your time.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 12-28-2007, 05:58 PM   #5
kuzo's Avatar
Send a message via MSN to kuzo
If you are going to buy new caps anyway, you might want to try the Yokomo bleeder caps. They are still plastic of course but I've had such good luck building and bleeding shocks since I got them. I'll try to dig up a part number if you want.
kuzo is offline   Reply With Quote
Old 12-28-2007, 06:15 PM   #6
Thankyou for the validation OG...its just crazy. They would be so simple if it were just metal on metal rather than this plastic crap. I dont understand why the aluminum caps are not included in a $225 kit. Souldnt be that difficult. Im taking break and going to try again. Im not giving up.
Old 12-28-2007, 06:46 PM   #7
d4man's Avatar
I 2nd both Jake S' and Kuzo's suggestions. Buy 2 packs of part number Yokomo Part Number YS-8Y and your caps become easier to bleed
The greatest trick the devil pulled was convincing the world he didn't exist...
I always thought I had a pretty good imagination, but it turned out to be just my imagination.
NOT a member of Team Terribles!
d4man is offline   Reply With Quote
Old 12-28-2007, 07:12 PM   #8
tony montana's Avatar
Trader Rating: 66 (100%+)
like above, get the yokomo caps and make life easier. much easier bleeding also
K.C. Guy- TLR- Horrizon Hobby- Team Trinity- 92 zero designs- AKA
tony montana is offline   Reply With Quote
Old 12-29-2007, 12:22 AM   #9
OK I have figured it out my friends....First you must meditate for one hour on the upcomming task at hand, find your Jedi center and proceed into the shock building arena with love, patience, and determination. With a gentle touch your persistance will be rewarded with 4 beautifully built shock absorbers. Finally I have become one the RC Gods. lol...mission completed.
Old 12-29-2007, 12:26 AM   #10
When i do my Associated shocks (B4), i turn the caps backwards until i feel it click, or fall over the beginning of the threads then i tighten it. You have to do this fairly quickly, but don't get to happy and ruin your caps.. I ruined several.
Good luck
Nick Carroll is offline   Reply With Quote
Old 12-29-2007, 08:02 AM   #11
OG RC 10T's Avatar
Welcome you are young shock builder.
Old 12-29-2007, 08:46 AM   #12
RodneyB's Avatar
I also like the Yoke bleeder caps as they are easier to build consistently, however I have also found them easier to cross thread when putting them on relative to the stock caps. That's just my experience anyway.
RodneyB is offline   Reply With Quote
Old 12-29-2007, 12:13 PM   #13
Thumbs up
Nobody uses the aluminum blue caps that are made by associated, my problem was not the bleeding and bubbles it was the darn cross threading. I thought for sure that I had ruined a couple of the caps by cross threading but I guess not...but I have heard this is not uncommon to strip them out. Alluminum just seems like a better option and they are not that heavy.
Old 12-29-2007, 12:19 PM   #14
UK.hardcore's Avatar
Get a LOSI!
J/K, J/K.
I used yokomo bladder caps when i ran Associated, would have too search the numbers.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 12-29-2007, 12:29 PM   #15
Tech Legend
Wild Cherry's Avatar
plastic caps are your best choice, follow the direction`s for your best results...
Hope this helps
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
tips for building shocks and gluing tires + others Apexs Electric Off-Road 1 02-10-2007 07:59 PM
building the perfect shocks Hrdluck13 Electric Off-Road 4 06-14-2006 07:02 AM
Building Ae shocks.... please read Trenton Electric Off-Road 11 08-02-2004 06:35 AM
Building shocks - advise me please Profoxcg Nitro On-Road 8 02-28-2004 09:17 AM
building shocks....? 2qwik Electric On-Road 3 12-10-2003 03:45 PM
