Old 12-24-2007, 07:55 AM   #1
JBRacing's Avatar
Default Orion/Track power balancing
How to you convert a regular balancer to plug into these packs?
JBRacing is offline   Reply With Quote
Old 12-24-2007, 04:40 PM   #2
1armed1's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to 1armed1
Go to the Trakpower or Flight power web sight and look at there balancer adapter for those packs.
I was able to look at there balacer plug and make my own adapter.
You will need a 2s balacer plug for your balancer, 2 banana plugs standard sized and 1 1.5mm or 2mm banana plug ( I don't remember the size) for the center tap.
later
Dayton
1armed1 is offline   Reply With Quote
Old 12-24-2007, 06:22 PM   #3
glassdoctor's Avatar
A 2s lipo balancer will have only three wires. The middle wire will go to the middle plug on the pack, and the two outside wires should be labled or color coded to tell you which is pos and neg....which connect to the same on the pack. It should be very simple... as larmed1 said, all you need to do is use the correct size bullet connectors for your pack and put them on the balancer lead wires.
glassdoctor is offline   Reply With Quote
Old 12-25-2007, 12:46 AM   #4
JBRacing's Avatar
Thanks to both of you.
So basically what I need to do is pull out the middle wire and connect it to the socked leaving the other two wire hanging.
Is that correct?
Thanks again
Old 12-25-2007, 03:52 AM   #5
tschenck's Avatar
Trader Rating: 110 (100%+)
I believe he means you connect those two wire to the positive and negative leads.
tschenck is offline   Reply With Quote
Old 12-25-2007, 06:26 AM   #6
1armed1's Avatar
Correct
Old 12-26-2007, 10:13 AM   #7
chrlie sidebite's Avatar
http://scriptasylum.com/rc_speed/_lipo.html
chrlie sidebite is offline   Reply With Quote
Orion/ICE balancing Flying Monkey Radio and Electronics 9 02-20-2009 10:52 AM
balancing orion 3600 lipo with a blinky David Wall Radio and Electronics 5 12-19-2008 08:52 PM
Balancing plug? Premium Power 4700 LOSI123 Electric On-Road 10 08-27-2007 04:12 PM
Balancing plug? Premium Power 4700 LOSI123 Australian Racing 6 08-22-2007 04:32 AM
Balancing Team Orion Carbon Edition 3200 Ralf 13 Electric On-Road 3 05-31-2007 10:06 AM
