Old 12-17-2007, 10:52 AM   #1
jasburrito's Avatar
Default B44 CVDs TOO SHORT???????????
Popped 1 out the other night during practice.
Looks as though the cvds should be about a mil longer,Though it may then hit nut side when compressed.
I popped right rear. Thinking of adding 1 more limitter
Yes the limiter is in shock
Camber correct (have added little more now though)
Camber lenth tight
jasburrito is offline   Reply With Quote
Old 12-17-2007, 11:36 AM   #2
aeRayls's Avatar
I added an extra limiter to the rear. I hated to use a good tuning adjustment as a crutch for the problem though. The main reason they fall out is the flexibility of the rear arms. If your so inclinde you can twist the arm by hand and make it come out.
aeRayls is offline   Reply With Quote
Old 12-17-2007, 12:44 PM   #3
jasburrito's Avatar
noticed rc8s cvds are plenty long.
Also looks as though if longer shaft would hit cup.
Kinda a crappy design.
Wish AE would have done a little more research.
Note when mine popped it was from sideways landing,not a crash. (close though)
Still pretty kick a$$,huge fun
Old 12-17-2007, 01:35 PM   #4
tyreman's Avatar
Have you tried shimming the CVD from the inside of the hub, so it sits deeper into the diff half.
Schumacher, Speed Passion, Speed Power, Custom Blitz, RudeBits, Sanwa, Racer, Ripmax, Muchmore Racing, B-Fast RC performance parts, Nuclear-RC
tyreman is offline   Reply With Quote
Old 12-17-2007, 02:29 PM   #5
Trader Rating: 39 (100%+)
No need to add any limiters or add more camber. +1 on shimming. Simply shim the axle on the inside of the hub to seat the cvd shaft deeper in the outdrive. I'm using 2 shims on the inside and no issues here.
ridgewaybodies is offline   Reply With Quote
Old 12-17-2007, 03:29 PM   #6
c0sie's Avatar
What limiters you guys using?
:: Carisma : Phat Bodies : Custom Blitz Paint : RCbearings : CML Distribution : UK-MicroRC ::
c0sie is offline   Reply With Quote
Old 12-17-2007, 04:16 PM   #7
1 limiter in the front and rear.
Old 12-17-2007, 04:17 PM   #8
c0sie's Avatar
Are you using the B4 limiters? Or o-rings?
Old 12-17-2007, 04:24 PM   #9
jasburrito's Avatar
Thought of that,might have to try.
Old 12-17-2007, 04:28 PM   #10
ASCC4187 .030" plastic limiters...yes, B4 limiters. Your kit should come with them...simply follow the shock building instructions and you will be golden. The kit set up is a pretty dialed starting point. The only changes I made so far was 35wt oil in the front, 30wt in the rear and a modified B4/T4 sway bar using the middle weight bar.
Old 12-17-2007, 10:39 PM   #11
im not running limiters in the rear and i was wondering about this problem. i will do the shiming. you know a little preventive matience. thanks for the tip
B44 B4FT
Associated all the way
GigerrcAE is offline   Reply With Quote
Old 12-18-2007, 04:18 AM   #12
Trader Rating: 54 (100%+)
Agree on the shimming...do not adjust via additional limiters.
WHOBEE is offline   Reply With Quote
T2 CVDs stiltskin R/C Items: Wanted to Buy 9 11-04-2007 06:10 PM
XXX CR cvds/ XXX BK1 theanimaleide R/C Items: Wanted to Buy 3 09-21-2007 09:27 PM
CVDS (TC3 OR TC4) SweetRacing R/C Items: For Sale/Trade 14 12-18-2006 05:21 PM
CVDs moelll Electric Off-Road 1 07-20-2004 12:31 PM
MIP CVDs fisher Electric Off-Road 14 10-17-2002 06:26 AM
