Old 12-16-2007, 05:28 PM   #1
Default wheelies 101
Hey guys, im new to this so i am trying all sort of stuffs. I got electric stampede. I have 86-spur and 19pinion.. and even with fresh charged battery i cant do wheelie. Unless i reverse and go forward full speed. From the videos seems like people do wheelies from stand still and even when in middle of run. Am i missing smth? Stampede not enough powerful in stock form to do wheelies from stand still? thanks everyone.
neupane00 is offline   Reply With Quote
Old 12-16-2007, 06:38 PM   #2
Trader Rating: 67 (100%+)
Default Wheelies
A lot of the videos you see are trucks with mod motors, brushless, lipos, and multiple cell lipos as well. About like dropping a 426 Hemi into a Neon and using rear wheel drive.
nutz4rcyktw is offline   Reply With Quote
Old 12-16-2007, 07:05 PM   #3
oh okay, i see. So does that mean stampede in stock form doesnt have enough power to do wheelies? Also you said rear wheel drive.. Does that mean 4 wheel drive trucks will have harder time doing wheelies?
Old 12-16-2007, 07:10 PM   #4
throw the nicad away and put a good battery in (joke).
which model do you have? xl1 or xl5?
Jaysun is offline   Reply With Quote
Old 12-16-2007, 07:27 PM   #5
I have xl5. i am 4500 NiMH 8 Cell (9 volt ) battery in.
Old 12-16-2007, 11:09 PM   #6
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default b
Upgrade tires and motor and you should be scratching the motor plate and body easy...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 12-16-2007, 11:14 PM   #7
wikedgmc's Avatar
R/C Tech Charter Subscriber
Trader Rating: 75 (100%+)
Send a message via MSN to wikedgmc
if you want it to wheelie the way it is, tighten the slipper up some
Powered by HobbyTown San Jose
wikedgmc is offline   Reply With Quote
Old 12-16-2007, 11:15 PM   #8
So i HAVE to upgrade motor/tires to get wheelies? What motor do you recommend? And what tires? Can u pls post a link? So does that mean stampede in stock form doesnt pull wheelies?
Old 12-16-2007, 11:22 PM   #9
wikedgmc's Avatar
upgrades are always cool, but all you need to do to make it wheelie is tighten the slipper
Old 12-17-2007, 03:42 PM   #10
streetracer745's Avatar
Send a message via AIM to streetracer745
ok youve come to the right guy! XL5 pede should rip the wheels up easy. especially on 8 cells. you do have the titan motor right? loosen the rear man. let the suspension get a little softer. that way mroe weight will go to the back tires. glue your tires if they arent glued already. and make sure your batteries are peaked. if they dont start fresh and full, they wont lift up. tighten the slipper as much as possible. out of the box its loose so it wont lift up as easy. and go for it. if that dont work, you have a fouled motor
89% of Revos are racers. If your Revo can out-bash and out-run a Savage, put this in your sig.
SMOKE TIRES, NOT DRUGS
46.7% of all statistics are made up on the spot and have no real value or truth.
streetracer745 is offline   Reply With Quote
Old 12-17-2007, 04:27 PM   #11
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Dont do that. You can and will destroy your transmission.
Tighten your slipper clutch.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 12-17-2007, 07:52 PM   #12
Hey thanks for reply. I have titan 12T motor. Ive made slipper tight. I have fresh charged the battery. I have tenergy 8 cell pack 4500 (with white tamiya (white 2 pin) connector). In my stampede it has deans connector. So i got deans to tamiya connector. Fresh charged the battery. ANd even with tight slipper i see no difference. Tires on stampede comes glued i think (dont know if its tight enough). I see its all rim is glued to tires.
Only think i dont have is loosen the rear. How do i loosen the rear suspension? I have no idea. Can u pls help with that?
Old 12-18-2007, 02:45 AM   #13
joe of loath's Avatar
do you have threaded shock bodies? if so just untighten the collars about 10 turns or so. if you dont, remove some of the spacers.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 12-18-2007, 09:18 AM   #14
a stiff rear suspension will make it loose traction. soft suspension makes it hook up. like stated before, take spacers or loosen the collars. if you have all the spacers out, either get softer springs, put thinner oil in the shocks, or cut a small amount of the spring off on the end.
Old 12-18-2007, 10:50 AM   #15
besides the clutch check to make sure your xl5 esc is not in training mode. If you have some spring spacers for the shocks add them to the front shocks. I would upgrade the connector to deans or the traxxas because with just a 7.2 3000 mine would get hot to the touch.
Baja 5B doing wheelies with X-Can!! GeneralG Electric Off-Road 18 08-15-2008 03:20 AM
revo wheelies? omega_revo Monster Trucks 15 02-26-2006 10:42 PM
savage doing wheelies car-wris Monster Trucks 14 04-16-2004 04:35 PM
tmaxx wheelies buggyman81 Monster Trucks 18 07-04-2003 02:21 PM
Wheelies buggyman81 Electric Off-Road 32 05-07-2003 09:42 PM
