Old 12-17-2007, 02:08 PM   #16
Syber Serulean's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to Syber Serulean
i think it has a regular slipper
Syber Serulean is offline   Reply With Quote
Old 12-18-2007, 09:56 PM   #17
What up?'s Avatar
Trader Rating: 14 (100%+)
Default XXCR
This is how my XXCR is set up from Pegasus the last time I ran it there.
Front Suspension
Spindle Carrier 25
Arms level
Front camber a 1 degree negative
Shock oil 30
Piston 57
Springs Blue
Not sure on the spacer (Possibly A)
Steering crank outside
Top shock tower hole 2 (2nd from the inside)
Inside Camber hole on shock tower hole 2 (2nd from the inside)
Outside arm hole
Outside Camber inside hole
Rear Suspension
Pivot at 0 degree's
Dog bones Or CVDs level
Rear camber -2
Shock oil 35
Piston 56
Springs Pink
Not sure on spacer but its possibly too large
Inside camber hole 7 2nd from the outside middle row
Inside arm hole
Only have two holes on the hub inside or very top.
On the old track layout I was running an 84 spur and 21 pinion all old stuff (1700 pack and trinity stock) I should have gone up one tooth on the pinion but ran out of time.
When the track was dry it worked really good but when it was watered it started pushing a little but still turned good. I like my cars a little loose.
The tranny ratio is 2:19:1
Hope that helps you and your buddy out. I will probly see you at the track soon for some racing.
Josh Mitchell
Speedtechrc.com / Team Orion USA / Airtronics / Proline / Bartalone Racing / rcinsider.com / 818Designs
What up? is offline   Reply With Quote
Old 12-20-2007, 01:09 AM   #18
awesome, thanks.
ya seein this, rusty?
Old 12-20-2007, 01:27 AM   #19
Trader Rating: 26 (100%+)
Send a message via AIM to cheesecake
when i ran mine i had the green spur gear and a 24 tooth pinion for stock motor gearing.
cheesecake is offline   Reply With Quote
Old 12-20-2007, 07:59 AM   #20
Casper's Avatar
Trader Rating: 34 (100%+)
Green spur is 88
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-27-2007, 06:00 PM   #21
air8's Avatar
Since the LHS doesn't have much available for these anymore, where are some other places that might have stock left. I might be using some suspension parts for a nitro oval sprint car, and I would like to know if I can buy parts before I build the car this way. If there isn't much out there then...oh well.
Thanx
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 12-27-2007, 10:06 PM   #22
Super Moderator
tmail55's Avatar
Trader Rating: 61 (100%+)
When I had a XX-CR last spring, gave it to a kid as a start in RC, I put some Duratrax BX front arms on it. A LHS gave me all the XX-CR parts they had at half price just to clear the space for 'new-er' parts.
Thinking I had to open up the bulkhead mount on the arms, about .030 for them to fit.
Isn't there a place called "Losi Parts House" OR something like that for 'mature' parts!!!
A AE B4 double slipper spur setup will fit, worked great on the XX-CR I had.
When I got the buggy the Hydra Drive had already been replaced.
Rev. Terrance / Team HOLY Rollers / R/C Tech > R/C Racers 4 Christ
Petit RC / RC WISH / RCTen.com #WeAreAE
I believe the word of God for what it says, not what people want it to say!
RC10GT2-E, SC5M, RC10T2, Spec-R S2, FX10
tmail55 is offline   Reply With Quote
Old 12-28-2007, 08:33 AM   #23
Trader Rating: 67 (100%+)
Default Parts
Losi Parts House is a great supplier.
You can search by type of buggy or truck or by part. They have many XX series parts. Some Duratrax parts will work on XX but not all. Compare closely before buying.
nutz4rcyktw is offline   Reply With Quote
Old 12-28-2007, 03:11 PM   #24
losi parts house is great i agree.
but their stocks, and especially XX stuff isnt great. @[email protected]
Old 12-28-2007, 05:20 PM   #25
metalracer2's Avatar
Trader Rating: 20 (100%+)
Send a message via AIM to metalracer2
i haven't had any problems getting parts yet lets just hope no parts brake
metalracer2 is offline   Reply With Quote
Old 12-28-2007, 11:55 PM   #26
air8's Avatar
Well, this is my first attempt at a nitro sprint 1/10 and I'm using a later model for the suspension so I don't know what to expect. I know the learning curve will be steep, and I'm sure I will enjoy it. With that being said, if the number of parts dries out, I guess I'll build a better one from what I learned on this one. LOL.
I don't think I will end up with too many XX parts on this sprint car though. Maybe steering rack, CV's, rear hubs, front hubs, spindles and axles, and maybe some links or hinge pins. I shouldn't be too worried overall. Thanx guys for the info.
--"U Ain't Fast!!"
Chris Pearce
Team Integy Setup Station 2 w Case and setup board - complete olhipster1 R/C Items: For Sale/Trade 4 11-02-2007 08:21 PM
WTT Mamba 6800 Setup for Tekin Mini Rage Setup Rc guy R/C Items: Wanted to Buy 0 08-07-2007 09:57 PM
XRay T2 Rubber setup, RC 10L4, 1/10 on road setup station jsmax R/C Items: For Sale/Trade 36 04-16-2007 08:56 PM
Integy Setup Station 2 TC w Case and Setup Board rezenclowd3 R/C Items: For Sale/Trade 10 02-24-2007 10:27 PM
almost prospec mbx5 f/t with engine for nitro touring setup or electric setup tony montana R/C Items: For Sale/Trade 13 02-03-2006 12:42 PM
