Old 12-12-2007, 01:59 AM   #1
Default Battery Advice Please
Howdy,
Newbie to the Hobby. My son (7 Y.O. ) and I are getting a used Rustler and Stampede for Christmas. I've got the trucks but need batteries.
I found a deal for some Hump Packs
High Capacity High Power Nickel Metal Hydride Battery Pack for RC cars.
NiMH technology enables convenient charging at any time. No cell memory effect. No need to fully discharge before recharging.
High power delivery with 38 Amp maximum discharge rate.
Standard Dimension: Height 1.5"; Width 1.7"; Length 5.5" inch, fits all RC10 cars
Weight: 15 Oz
Capacity: 3800 mAh
Voltage: 8.4 V
Connector: Standard Tamiya
Standard Charge: 12 hours @ 300 mA
Rapid Charge: 1.5 hours @ 3000 mA
The cells are labeled "Tenergy".
Are there any serious drawbacks to using the 8.4v packs? Both of the Traxxas rigs have XL-1 ESC and Stinger motors.
Also any feedback on the Tenergy cell packs themselves?
Thanks,
Michael
mjcostel is offline   Reply With Quote
Old 12-12-2007, 02:32 AM   #2
joe of loath's Avatar
so, these are 7 cell (airsoft style) stick packs right? they should work with the ESC and give a bit more speed (maybe 5mph more). these should be fine, unless you're racing, when you'd want some nice 4200mah packs.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 12-12-2007, 02:36 AM   #3
never heard of those but you can get some venom packs in 3000 MAH pretty inexpensive (6 cell 7.2 v) and trinity is also coming out with inexpensive packs as well. (6 cell). max amps also has some good packs. from personal experience if you are not going to be running these weekly i would STAY AWAY from 4200's. they need at least weekly attention!
mugenlife is offline   Reply With Quote
Old 12-12-2007, 02:56 AM   #4
Default They are seven cell packs
They are the seven cell packs. I am not going to be racing at all, but thought it might be nice to have a little extra punch.
Mostly I was wondering if I might be more apt to damage the motor or other components by running above the more standard 7.2V packs.
Also, any guess how long a run times I might get from the 3800Mah packs on the mostly stock Rustler and Stampede?
Michael
Old 12-12-2007, 06:41 AM   #5
wog....supraman's Avatar
Send a message via MSN to wog....supraman
hold that brain train......has anybody asked the question of 'will it fit in the car' shouldnt that be the first concern???? coz it is pointless having a 7-cell pack.....if it dont fit in the tray.
Tamiya TNX5.2R, Taniya TA05, Tamiya TB-02, Team Associated Factory Team B4, Twister CP V2, HoBao Pirate 10 MT, Tamiya TNX5.2R spare chassis x2, ebay spec submarine, HSP Rock crawler! FOR SALE!!! pm me
wog....supraman is offline   Reply With Quote
Old 12-12-2007, 07:01 AM   #6
Default Will it fit?
The 7th cell is right in the center top of the standard Traxxas 6 pack configuration. It looks like it will fit with no problem.
Thanks,
Michael
Old 12-12-2007, 08:26 AM   #7
Casper's Avatar
Trader Rating: 34 (100%+)
I would get some cheap 6 cell stick packs. Look for 3300 or better. There are a ton of companies that make inexpensive stick packs.
Slingshot Batteries
Orion
Reedy
Trinity
Venom
and others.
Your LHS should have a couple to choose from. For you guys that are just getting started, get some stick packs and have some fun.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 12-12-2007, 09:09 AM   #8
GRIMREAPER's Avatar
Send a message via AIM to GRIMREAPER
are these batt any good
http://cgi.ebay.com/11-1V-10C-8000mA...QQcmdZViewItem
GRIMREAPER is offline   Reply With Quote
Old 12-12-2007, 09:17 AM   #9
Casper's Avatar
Lipos require special chargers. That will be way too much voltage for you guys if you are learning how to drive though. You want to keep the car controllable as you learn the ropes and start strapping in more speed. Have fun with the cars and learn to drive them. If you make them go to fast it will get frustrating and you will break stuff all the time.
Old 12-15-2007, 07:46 PM   #10
hyperguy's Avatar
Trader Rating: 22 (100%+)
IF YOU ARE JUST WANTING TO PLAY AROUND THEN YOU CAN JUST GET SOME 1800'S OR SOMETHING OF THAT SORT, THEN YOU WONT HAVE TO GET ANY SPECIAL CHARGERS THAT WILL CHARGE NIMH OR LIPOS, YOU CAN GET AN INEXPENSIVE CHARGER AND HAVE FUN
hyperguy is offline   Reply With Quote
Old 12-15-2007, 08:20 PM   #11
Trader Rating: 26 (96%+)
Second on some cheap nicds. I would just go with these.
http://www3.towerhobbies.com/cgi-bin...?&I=LXJA83&P=0
They will discount the price some if you order multiples, just look on the page for the part w/ multiples. With these packs you should only run them once in a day, but you can purchase like 10 of them and a cheap nicd charger all for under $100. You should get around 5 minutes of run time w/ a battery so you can charge up your packs and run the two cars for 5 minutes, let them cool for a few minutes & then run them again. To be on the safe side I would pick up two chargers, I doubt they are built to charge 10 packs or so in a row so you can alternate them back and forth so they last a long time.
http://www3.towerhobbies.com/cgi-bin...?&I=LXSG85&P=0
those should make fine chargers for what you need.
This setup should last you a whole lot longer then a nimh pack w/ a charger for each of you. If you look on the front of towers site you can also find discount codes.
party_wagon is offline   Reply With Quote
Battery and Charger advice needed te04rx8 Rookie Zone 7 04-29-2009 06:29 PM
Battery advice ! Martinst Rookie Zone 8 03-03-2008 07:23 PM
Battery Advice vazzo Australian Racing 9 03-26-2007 06:10 AM
My Pulsar 2 taking 45 mins to charge a 3600 battery? Advice needed please... Jhyten Electric Off-Road 5 02-18-2006 11:03 PM
Battery Advice and questions Stevietd14 Electric Off-Road 4 10-09-2005 07:56 AM
