PROBLEM WITH THE B44:flaming::flaming::flaming:
I DONT REELY KNOW HOW TO DESCRIBE IT BUT THE FRONT END IS MAKING LIKE A CLICKING NOICE BUT IS SOUNDS LIKE THWERE IS A ROCK IN THE FRONT DIFF.
HAS ANYONE HAD THIS PROBLEM???
HOW DO I FIX IT??
THANKS PETER
HOW DO I FIX IT??
THANKS PETER
I am sure it is the ring or pinion chuncked a tooth. I bet if you open the trans case you will find a munched tooth or two. It happened to me. I just replaced it and went back at it.
I BAWT A SWEET REPLACEMENT GEAR ON EBAY FOR MINE....ITS ALUMINUM AND IT LOOKS AWESOEM.....ITS BLUE....ALSO GET SOME ALUMINUM ARMS FOR THE CAR THE 1S ITS COMES WITH ARE WEAK....TAKE IT TO THE PLACE YOU BOUGHT IT AND TELL THEM TO FIX IT FOR YOU FOR FREE SINCE THEY SOLD IT TO YOU AND THEY SHOULD STAND BEHIND THERE PRODUKT.
Just kidding, buy a new front diff gear and replace the broken one. Next time make sure not to over tighten the slipper clutch.
It will also happen if the car is cold from the trip to the track. I had a bj4 strip a bunch of teeth when they were cold and brittle. The car rode in the back of my pickup that day.
thanks guys i figuered it out
what was it?
what was what?????
the problem
the e clip came out and got jammed in the gears
All that 'flaming' in your thread title and it was actually caused by you
wow
wow
