Old 12-02-2007, 02:07 PM   #1
Joe18's Avatar
Default Overheating electronics, limits and remidies
Hello I`m running a mamba 7700Kv in my t4 20 tooth pinion standard spur, and a 6 cell Ib4200 pack the pack is reaching 160 F, Esc 120F (mamba (is this ok)) and the motor is ok at 120F. What should I do? lower the gearing?
Any tips on lowering any other electronics temps are great too.
Oh and would the same thing happen to lipo?
Maxamps lipo pack 4200 mAh 11.1v http://cgi.ebay.com/Maxamps-4200mAh-11-1v-lipo-pack-R-C-car-Like-New_W0QQitemZ370040657843QQihZ024QQcategoryZ34061QQssPageNameZWDVWQQrdZ1QQcmdZViewItemfor sale-
Joe18 is offline   Reply With Quote
Old 12-02-2007, 05:51 PM   #2
wfdfiremedic's Avatar
The 7700 is prolly pulling some serious amps and the result is the heating of the battery. I see the same thing when running crappy packs with a mild brushless. Also, 20 tooth pinion seems pretty large for a st with that motor. Maybe try using a smaller pinion. yes, lipo will not heat up to the same degree assuming you get a quality lipo with a good C rating. They are capable of delivering more amps.
wfdfiremedic is offline   Reply With Quote
Old 12-02-2007, 05:55 PM   #3
Trader Rating: 26 (96%+)
The right lipo will stay cool.
party_wagon is offline   Reply With Quote
Old 12-02-2007, 06:29 PM   #4
Old 12-02-2007, 06:38 PM   #5
Joe18's Avatar
ok I`m sorry i didnt mention above but the reason I`m running a 20 is cause
I have moabs on it and to get good speeds I need the 20. Well this sucks I didnt want to go lipo but i guess i have to. thanks.
Old 12-02-2007, 09:08 PM   #6
glassdoctor's Avatar
The motor and esc temps are very cool. This is definitely a problem with the battery not being able to keep up.
The gearing also sounds a bit high to me unless you are running in the street. Especially with big tires like Moabs. I run my T4/5700 about the same gearing with stock tires.
glassdoctor is offline   Reply With Quote
Old 12-02-2007, 10:05 PM   #7
josher2468's Avatar
Yeah Thats an O.K. Temp. But it should be at about 70-100F.
josher2468 is offline   Reply With Quote
Old 12-03-2007, 08:10 AM   #8
Joe18's Avatar
so, New cells (prob ep`s) or lipo? any opinions, info, cheap if possible.
oh and josh I already know youre awnser so dont even.
Old 12-03-2007, 11:29 AM   #9
motor and esc will never run that cool
I would try dropping a tooth or two and see how it does. IB4200s are good (when they don't explode) so unless you have a weak pack I don't see how another nimh would help. If you want to try a nimh... go with an EP pack (red and black cells).
A123 or lipo is the best bet. It will cut weight and give more rip too.
Mamba25 Brushed Motor wiring & limits ghiro Micro and Mini Scales 10 06-02-2008 02:07 PM
Tamiya Battery Plug Limits andy85 Electric On-Road 5 09-11-2007 06:57 PM
Comm size limits bvoltz Rookie Zone 5 08-18-2005 07:23 AM
RC18T/MT ESC Limits? New_Toasted Electric Off-Road 4 05-11-2005 12:51 PM
12 turn motor limits...Your experience? Simon K Electric On-Road 50 07-11-2004 09:45 PM
