Old 11-29-2007, 10:15 PM   #1
Trader Rating: 42 (100%+)
Default please HELP!!!
ok i have a question for everyone i need some help figuring out this problem i have with my radio/esc/servo. I have a ko helios, with a hi-tec 6965 servo, and a quantum competion 2 esc. everything works fine with this combenation. I have another car i am going to use this JR900s servo in. when i plug it all in and turn it on it looks as if everthing is ok, but when i have the throttle at any position, and turn the wheels, the motor pulses and loses power. i have no idea what is going on. if anyone could help or give me any ideas of what to do that would be great because i am at a loss. Both servos are digital servos.
thanks
Haulenass210 is offline   Reply With Quote
Old 11-29-2007, 10:24 PM   #2
UN4RACING's Avatar
Trader Rating: 22 (100%+)
thanks
What shape is the motor in? It may need trued and new brushes installed.
Try another motor and see what happens.
UN4RACING is offline   Reply With Quote
Old 11-29-2007, 11:03 PM   #3
the motor was just turned and new brushes we installed.
Old 11-29-2007, 11:22 PM   #4
UN4RACING's Avatar
In order to be sure you will still have to change the motor. Or just hook one up. Its part of the process of elimination. Then you have to unplug the servo and plug another in to see if its the servo.?
Old 11-29-2007, 11:27 PM   #5
ok it does it with another motor, it does it with 2 of the three servos that i have, it does it with the 2 esc's i have(both are qc2's).
Old 11-30-2007, 12:02 AM   #6
UN4RACING's Avatar
Do you have another receiver. Use the one off of the other car.
Are you using the same radio.?
Old 11-30-2007, 12:03 AM   #7
Send a message via ICQ to cmain
try one of these if it is a spektrum receiver
http://www.horizonhobby.com/Products...ProdID=SPM1600
it may be the servo/motor combo is pulling to much juice and the radio goes into failsafe
cmain is offline   Reply With Quote
Old 12-02-2007, 12:23 PM   #8
hyperguy's Avatar
i use one of these and if helps alot.
hyperguy is offline   Reply With Quote
Old 12-02-2007, 10:18 PM   #9
I had a novak fusion esc that did that same thing. It only happen when I use a high speed servo. I guess it would draw more juice than the esc could handle. It worked fine with a 590z servo but not with a 94357. Try a different servo first if you have one.
desertraton is offline   Reply With Quote
Old 12-02-2007, 11:53 PM   #10
RussB's Avatar
Send a message via MSN to RussB
are the right crystals in the tx and rx?
RussB is offline   Reply With Quote
Old 12-06-2007, 11:26 AM   #11
tenpins77's Avatar
Send a message via AIM to tenpins77
Hey, check out that specktrum cap, works wonders, trust me ! Also, watch what type of servo you have? i was having glitching issues, when i was using a high torque futaba servo, that was draining the current of my batteries down too low. Causing my ESC and Servo to glitch. Unlike nitro cars, that have a seperate battery pack designated to the servos, on electric cars, we have our main battery pack
good luck, keep us updated
tim
tenpins77 is offline   Reply With Quote
