B44 conversion to T44 >
Old 12-15-2007, 12:36 AM
  #16
eds24's Avatar
Trader Rating: 56 (100%+)
If I had the money for a B44 I would totally do this conversion.But I don't right now becuase I am working on this project... http://rctech.net/forum/showthread.php?t=146640
It is basically a Tc3 that has been converted to a 4wd truck. So its alittle different then a B44 turned into a T44 but its the same concept and I thought I might share. If anybody is willing to lend me there B44 I would be happy to convert it to a T44. If there is a will there is a way. I bet t4 a-arms ,cvds,turnbuckles would fit. It really doesn't sound like a hard task.
eds24 is offline
Old 05-03-2008, 12:57 AM
  #17
I just converted my B44 to use QC GT2 wheels because I have a race on a very rough blowed out 1/8th scale track that I needed to use step pins all the way around and extra ground clearance.
Easy to do. I just ordered an extra set of bones for the B44, CVD kits, some GT2 Axles with retainer rings, QC Hubs. You will need 4 axle shims and 1 conical washer that you can use from the rear on the front on each side of the front to shim the hub out away from hub bearing carrier. The rear will need only 1 axle shim.
The front track is wider that the rear track that I may see if I can use the GT2 rear bones with either T4 or GT2 A-Arms. It also could use the extra shock travel of the truck too.
Everything fits up great and I am going to race it today.
Pictures will be posted when I get time.
Craps is offline
Old 05-03-2008, 08:33 AM
  #18
glassdoctor's Avatar
Sounds cool. We need pics when you get it all sorted out.
glassdoctor is offline
Old 05-05-2008, 11:43 PM
  #19
hopbot's Avatar
pics would be great! i've always wanted a 1/10 scale truggy class! before truggies were around, i had a kyosho optima mid extended that i converted to a truck. i was the only one of those at the track though so i could never race
hopbot is offline
Old 05-06-2008, 03:48 AM
  #20
shy@klp.no's Avatar
YES! A 1:10 Truggy would be awesome!
I saw A Main Raceway had plans for making a truggy conversion kit for XX4/XXX4 -anyone heard anything more about that?
Anyone know of anyone having plans for making a truggy or a conversion kit for wholesale?
shy@klp.no is offline
Old 05-06-2008, 04:05 PM
  #21
I did use a el cheapo HSP car, no something raceable without a lot of work on it, but still fun.
http://www.rc-monster.com/forum/showthread.php?t=11218
Mister-T is offline
Old 05-06-2008, 09:27 PM
  #22
Trader Rating: 38 (100%+)
Craps! How dare you post about your 1:10 truggy and not post pics right away!
Attached Thumbnails B44 conversion to T44-actionshot.jpg   B44 conversion to T44-actionshot2.jpg
mattnin is offline
Old 05-06-2008, 09:35 PM
  #23
Trader Rating: 20 (100%+)
I saw it run this weekend craps did a good job on it. He was jumping everything the 1/8 scales were.
xxxtruck is offline
Old 05-13-2008, 07:41 AM
  #24
hopbot's Avatar
just a bump: would love to see pics of the conversion and part numbers if you have them
thanks!
hopbot is offline
Old 05-13-2008, 02:55 PM
  #25
Same , I would buy a B44 only for getting a T44, 1/10 Truggy, probably awesome handling. Exactly what I'm looking for.
Mister-T is offline
Old 05-13-2008, 02:56 PM
  #26
beast95451's Avatar
CRAAAAAAAAAAAAAPSSSS. Where are the pics???
beast95451 is offline
Old 05-13-2008, 05:31 PM
  #27
Guys just follow my instructions. It is real simple to do! You will be real happy with it.
Been out of town alot and have not had time to post pics! Sorry!
Craps is offline
Old 05-15-2008, 05:43 PM
  #28
mkiiina's Avatar
Trader Rating: 70 (100%+)
please post some pics and part numbers! i am dying to make my own truggy as no mfg will step up it seems. what did you end up using for a body btw?
mkiiina is offline
Old 05-16-2008, 10:53 PM
  #29
HEAT's Avatar
Trader Rating: 26 (100%+)
Pics please would like to see this !
HEAT is offline
Old 06-30-2008, 10:49 PM
  #30
Default t44
almost done.. just need electronics
rc51ed is offline
