Old 11-27-2007, 08:21 AM   #16
c0sie's Avatar
My 2cents.
Take Off tyre glue is hugely popular at National level here in the UK.
:: Carisma : Phat Bodies : Custom Blitz Paint : RCbearings : CML Distribution : UK-MicroRC ::
c0sie is offline   Reply With Quote
Old 11-27-2007, 11:20 AM   #17
foolio's Avatar
I just wanted to mention that if you or someone is new to gluing up tires, the Loctite Gel SuperGlue is great. You can actually put a thick bead around the rim and it will give you plenty of time to position tire properly before it sets up. Of course, if you need the tires in a pinch, this is not as desirable. You probably want to let it set up overnight.
Now that I am a little better at gluing, I prefer the thin glues for that very reason. It set's up almost instantly. I have had good luck with both the Proline and Losi glue. I liked the Proline bottle better. While the Losi glued the tires up nicely, I eventually had to toss out half the bottle because the cap became fused with the bottle.
foolio is offline   Reply With Quote
Old 11-27-2007, 11:23 AM   #18
rripp's Avatar
Kyosho glue is the best that I have tried.
-Rod Rippee
Team Associated/Reedy Powered/Factory Team/SmacTrac Raceway/JConcepts/B&L Hobbies/Kiefer Designs
rripp is offline   Reply With Quote
Old 11-27-2007, 11:25 AM   #19
Trader Rating: 26 (96%+)
All I do is scuff up the rims where the tire will be glued w/ sand paper. Then I mount the tire & put rubber bands over the sides of the tire where they will be glued. Then I take a medium bottle of ca that you can pick up at just about any hobby shop. I then give it a little squeeze and run it around the side. If you get glue thats too thin the excess stuff will run all over the tire & make a mess.
party_wagon is offline   Reply With Quote
Old 11-27-2007, 11:52 AM   #20
Trader Rating: 33 (100%+)
kyosho or fusion.. i just mount them, and glue them.. thats it..
Daniel Grobe
Sponsors:
Proline Racing / RC America / Xray
dgrobe2112 is offline   Reply With Quote
Old 11-27-2007, 04:30 PM   #21
associatedguy's Avatar
Ask tasker what he uses. It seemes to work good on the tires he glued for ryan.
CEN Matrix FRE Buggy
Novarossi P5 with a 9886 pipe
KO Helios w/ spektrum
associatedguy is offline   Reply With Quote
Old 11-27-2007, 08:35 PM   #22
magm20001's Avatar
Muchmore
RIP Kanye West ..... Mom
magm20001 is offline   Reply With Quote
Old 11-27-2007, 09:44 PM   #23
FrankW's Avatar
I use thick Flash CA. I usually scuff up the bead of the rim and tire and clean both with denatured alchohol first. Never had a tire come off the rim when doing it that way.
-Frank
http://williams-luge.com
FrankW is offline   Reply With Quote
Old 11-27-2007, 09:51 PM   #24
alexb2000's Avatar
Advantage tire glue, works just like the fusion glue just cheaper.
www.carolinasrc.com
www.carolinasrc.com
The only place to get your RC stuff
alexb2000 is offline   Reply With Quote
Old 11-28-2007, 08:23 PM   #25
Iuse losi glue its the best
team james
www.banzaimotors.com
B.JAMES is offline   Reply With Quote
Old 11-28-2007, 08:37 PM   #26
magm20001's Avatar
you got part number for the losi glue?
Old 11-28-2007, 09:33 PM   #27
Tim W.'s Avatar
LOSA7880 Team Losi Tire Glue, Std
LOSA7881 Team Losi Tire Glue, Thin
Mugen Seiki, AKA, Werks Racing USA, Flashpoint, Upgrade
Tim W. is offline   Reply With Quote
Old 11-29-2007, 07:42 AM   #28
Good job
team james
Tire glue? lowey79 Nitro Off-Road 17 09-11-2008 05:23 AM
tire glue HELP jedsled Electric Off-Road 9 04-16-2008 06:27 AM
Best tire glue LogiK Nitro Off-Road 28 04-12-2008 10:09 PM
Tire Glue HELP srowell3 Nitro On-Road 1 02-22-2007 12:59 PM
trc #902 tire Glue WTB rcfoolz R/C Items: Wanted to Buy 0 12-11-2006 04:47 AM
