Old 11-24-2007, 02:45 PM   #1
xsxracing's Avatar
Trader Rating: 33 (100%+)
Send a message via Yahoo to xsxracing
Questions?? Rc10t4 Build !
I am thinking about buying the Rc10t4 Kit.
I have built a few rc kit's in my time.
Is the rc10t4 hard to build?
MrDave3D
xsxracing is offline   Reply With Quote
Old 11-24-2007, 03:11 PM   #2
Trader Rating: 27 (100%+)
the t4 is amazing, It was my first kit and it went together flawlessly, the only thing i have trouble with is the shocks.
C_Money is offline   Reply With Quote
Old 11-24-2007, 03:12 PM   #3
xsxracing's Avatar
Ya the only problem's i think i would have is building the shocks and diff correct.
MrDave3D
Old 11-24-2007, 03:20 PM   #4
Yeah those were the 2 hardest parts but still pretty easy.
Old 11-24-2007, 03:25 PM   #5
xsxracing's Avatar
Hmmmm
MrDave3D
Old 11-24-2007, 03:29 PM   #6
its a great kit, its worth it
Old 11-24-2007, 03:34 PM   #7
Suspended
Trader Rating: 21 (100%+)
I have raced this truck for a few years now. The trick to the shocks is as follows:
Assemble the innereds with the nifty little shock tool and read the directions carefully!! When it comes time to the oil, fill the shock right to the top, SLOWLY raise the piston up and down. Fill the shock again to the top, maybe just a tiny pinch over but don't let it spill. Now put the shock top on hand tight, slowly compress the shock, it's gonna compression binde, when it does, slowly lossin the top while compressing the shock. The fluid should leak out and the piston will rise to the top, WITHOUT RELEASING THE PRESSURE, tighten up the shock top tight. As for the diff, Its harder to screw it up then do it right.
The Slayer is offline   Reply With Quote
Old 11-24-2007, 07:25 PM   #8
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
I have built several associated trucks and most recently the B44. Associated kits are great to build and the directions make it very easy to understand. Once you build the shocks once and the rear dif once, you will see how easy it is.
With in the last 2 months I have built a Kyosho lazer zx5 which was difficult and took me 20 hours, total. The associated b44 took me under 12 hours total, and was easy.
Buy the kit and if you have any questions just post up.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 11-24-2007, 07:53 PM   #9
Well the problem I had with my shocks it that I built them the first time then ran the car, found the arms to be soaked in oil took them apart the o rings were cut,then when I tried to rebuild them everytime the parts snap in place I break an o ring, so I have no idea how to solve that problem
Old 11-24-2007, 08:56 PM   #10
ray3619's Avatar
when im having trouble i make sure to green slim all parts on shock tool , then after snapping in place i re green slim the tool and insert it from the bottom to make sure everything is green slimed on the inside , if you cant slide the tool in how are you gunna slide a threaded shaft in , then green slim the shock shaft and insert , most of the time i use after market silicone o-rings , stock are ok , hope this helps , ray
ray3619 is offline   Reply With Quote
Old 11-24-2007, 09:36 PM   #11
its just weird cause i cant snap the part in place without having the o ring get cut in half. I green slime everything but it still gets cut. its the weirdest thing
Old 11-25-2007, 01:15 AM   #12
OG RC 10T's Avatar
That has happened to me a few times too. I have never used green slime, just shock oil.
Put all of the pieces on the shock tool and put a couple of drops of oil on the o-rings and other parts. Keep the bottom end of the tool on the table and place your shock body over the tool untill it seats in place and you can see the tool coming out of the shock shaft hole. Press down firmly untill you hear the Click and see the tool sticking out further than it orgionally was.
Thats it. Just be patient, work slowly, and dont be afraid of using too much oil or slime.
Old 11-25-2007, 01:25 AM   #13
JeromeB's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to JeromeB
I had trouble the first time I built the AE shocks, mainly because I rushed it.
Take your time. Use green slime on all the internals, works far better than the shock oil. Use fine sand paper to smooth down all the burs on the spaces and pistons.
As for the bleeding I still have a little trouble, its just messy. I also found that using the tools to tighten the shock caps caused bleeding as it destroys the rubber seal, just hand tighten them and the seal will do its job.
The diff is cake. Set it as it says in the manual and its perfect.
JeromeB is offline   Reply With Quote
Old 11-25-2007, 06:56 AM   #14
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
Yeah, the associated diffs are amazing and very easy to build. My first kit was the b4 and the first time I built the diff it was super smooth, take your time with the diff too and make sure that you read all the steps. My first and only diff is over a year old and still smooth!!!
crazy4wdracer is offline   Reply With Quote
Old 11-25-2007, 08:08 AM   #15
MannEdge's Avatar
Trader Rating: 19 (100%+)
Has anyone tried these shock caps.
It makes it so easy. I replace shock oil in mins. It is that easy.
Rcgroups feedback -
http://www.rcgroups.com/forums/traderratings.php?u=78357
MannEdge is offline   Reply With Quote
RC10T4 or XXX-T? Winter Build Mizgo Electric Off-Road 17 07-24-2007 03:20 PM
Build it yourself. TDyk Electric Off-Road 9 01-12-2007 10:18 PM
WHY BUILD IT WHEN YOU CAN BUY IT? wurthusa R/C Items: For Sale/Trade 5 05-16-2006 10:32 AM
Diffewrence between rc10t4 and rc10t4 FT HELP!!! yellowpasta2000 Electric Off-Road 7 02-13-2006 08:47 AM
HPI R40 Build beowulf1877 Nitro On-Road 11 07-28-2004 09:44 PM
