Old 11-24-2007, 08:04 AM   #1
Alltapdout's Avatar
Default racing on cold day's
It is that time of the season when the temp. is droping down outside. My question is: are there any tips or ideas on battery care when racing in cold weather?
I know that a battery loses half its amperage when the temp is 32'F. Do most people keep there battery's inside untill its race time to keep them in a higher ambient temp, or do most of you just run them?
Thanks.
Alltapdout is offline   Reply With Quote
Old 11-24-2007, 08:42 AM   #2
sosidge's Avatar
Where did you get that figure from? Seems a bit extreme to me.
Just keep them out of the most exposed cold and you should be fine, charging and racing them ill warm them anyway.
Old 11-24-2007, 08:58 AM   #3
Alltapdout's Avatar
Well now I think about it, and I think that was for liquid filled battery's. So I guess that may be alittle extreme. But I do see a significant difference in "punch" and run time when its cold out.
Old 11-24-2007, 09:03 AM   #4
sosidge's Avatar
I agree, the packs do seem a bit softer when it is cold.
By the way if you are really having problems Much-More make a cell warming tray.
Old 11-24-2007, 11:49 AM   #5
Drew Manzella's Avatar
Trader Rating: 28 (100%+)
Years ago when we were running dirt oval outside in the cold we all had those cheap, soft coolers. We'd cut a hole for the wires and charge the batteries inside the cooler. The heat generated by the battery while being charged was retained within the cooler.
You can probably pick one up at Walmart for a few bucks. You don't need anything more than a 6-pack size. Something like this:
It might even help to throw some towels in to fill a bit more space and keep it in the house until you leave for the track so as much heat is retained in it as possible.
Drew Manzella is offline   Reply With Quote
Old 11-24-2007, 04:42 PM   #6
MikeXray's Avatar
Trader Rating: 73 (100%+)
what about shock oil, I've seen people mentioning going higher when its hot, how much lower do you go when its cool?
Mike L. Awesomatixusa.com | TQWire.com | Islandraceway.com |JacksonRCracing.com | Horsham RC | Sweepracingusa.com
MikeXray is offline   Reply With Quote
Old 12-06-2007, 11:37 AM   #7
tenpins77's Avatar
Send a message via AIM to tenpins77
i just want to know how you can stand there freezing your A$$ off in the first place
tenpins77 is offline   Reply With Quote
Old 12-06-2007, 02:17 PM   #8
sport10's Avatar
You generally go down 5 weight in oil from what I remember.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 12-06-2007, 02:24 PM   #9
jkirkwood's Avatar
They say the silicone oils shouldn't change when it's cold or hot but I beg to differ and most team driver's will make adjustments to their setups based on extreeme temp changes. However it's probably no more than 5 wt from 95 deg to 50 deg. Some people will fill it others wont.
I take a heat gun with me to warm up the car a bit if it's really cold. This seems to help with parts breakage as the cars get brittle. If you are really worried about it some people boil arms, pivot blocks to soften them up a bit for colder weather.
jkirkwood is offline   Reply With Quote
Old 12-06-2007, 02:43 PM   #10
Not everyone is a wuss.
Drew - Who just got home from the Thunderhill 25 Hour where it was snowing at 4:30AM.
Engines and the Cold Woof Nitro Off-Road 12 11-25-2007 04:26 PM
Hot or Cold Plug? Wyle E. Coyote Onroad Nitro Engine Zone 7 07-16-2007 08:45 PM
Cold Heat ZeroCooL Electric On-Road 62 01-10-2006 06:48 AM
Cold weather glitching? fatdoggy Electric On-Road 4 10-19-2003 06:10 PM
