Old 11-21-2007, 02:10 PM   #16
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
another tire to try is the stock Fusion tires that come with Academy cars. These are similar to a holeshot but alternate block and pin instead of just blocks. These work very well, great wear characteristics, and they don't load up like a holeshot does.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 11-22-2007, 11:59 AM   #17
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
The panther switch are designed for the type or condition of track that you are describing. They are not that expensive either and have a good life span.
Give them a try, I have used them and dont have any complaints. The track here is usually dusty clay, hard packed underneath, and ocassionally watered.
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 11-22-2007, 12:35 PM   #18
Casper's Avatar
Trader Rating: 34 (100%+)
With really light dust switches will work but any type of fluff and they will be loose.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 11-22-2007, 04:57 PM   #19
I second the vote for Red Bigshots and the Academy Fusion tires on a hardpacked non-clay track with a loose/fluffy surface.
Stealth_RT is offline   Reply With Quote
Old 11-24-2007, 08:33 AM   #20
hyperguy's Avatar
Trader Rating: 22 (100%+)
all these tires are a good choice
hyperguy is offline   Reply With Quote
Old 11-24-2007, 10:51 PM   #21
B4Bandit's Avatar
Sounds to me like bigshots.
I run on similar conditions to what you describe and they are the tire of choice.
B4Bandit is offline   Reply With Quote
Old 11-25-2007, 12:10 AM   #22
Alltapdout's Avatar
http://www.losipartshouse.com/servle...l?sfs=e1899b5b. These are the losi studs.
Has anyone ran the inside job fronts?
Alltapdout is offline   Reply With Quote
Old 11-25-2007, 12:54 AM   #23
raceGEEK's Avatar
play around with the losi blockheads, interesting tires, last quite a while too. Since when did the discontinue the pin tires? cause that really sucks. losi tire selection is really coming down to only a few choices in the 10th buggy world
looking for xxxcr parts
xxxcr
xxx4
xx4
raceGEEK is offline   Reply With Quote
Old 11-25-2007, 12:57 AM   #24
Trader Rating: 42 (100%+)
We use Panther soft pumas for the buggy and komotos on the truck. For hard pack, we use switches 2.0 soft in the back. Try softer foams in the back and harder in the front for the truck.
desertraton is offline   Reply With Quote
Old 11-25-2007, 12:59 AM   #25
Turbo Joe's Avatar
I run the Inside Jobs on the front of my Lazer...I wish I had used some better inserts in them, but they work pretty well at the track I race on (Pegasus).
If you stay in the more packed part and out of the dusty stuff, they're great. If you go wide, good luck....you're going straight.
Turbo Joe is offline   Reply With Quote
Old 11-25-2007, 06:00 AM   #26
Alltapdout's Avatar
@ Turbo, are you talking about the inside jobs, or the losi pins?
The link I posted earlier was for ifmar studs, not pins, my bad.
Old 11-25-2007, 11:20 AM   #27
Turbo Joe's Avatar
LOL...the inside jobs. I have no idea where that quote came from, I'll go fix it.
Old 11-26-2007, 04:05 PM   #28
That must be a toyota answer
team james
www.banzaimotors.com
B.JAMES is offline   Reply With Quote
Old 11-26-2007, 04:15 PM   #29
Turbo Joe's Avatar
LOL...I'm a Ford guy, I just get the Toyota shirts for free.
Old 11-27-2007, 08:46 PM   #30
So do you work for ford and wear a toyota shirt
team james
Truggy vs MT for Bashing and Tire Selection Jaynen Monster Trucks 7 12-13-2007 07:13 PM
Tire question wcalaker Rookie Zone 6 12-03-2005 07:25 PM
Tire Selection donoman Electric On-Road 8 08-23-2004 06:52 AM
Foam Tire Selection for TC3, questions Cain Electric On-Road 9 03-16-2004 07:10 PM
Question About batteries, 2400 mah Battery selection taybelZ Rookie Zone 1 10-08-2002 02:58 AM
