Old 11-14-2007, 02:07 PM   #1
Default PONDERING XXX-T CR
i have a losi mf-1 and would like to convert it to the cr, was wondering whether it is worth it or not i really like the q.c. rear hubs and ability to use same wheels front and rear if anyone knows the parts that i need or has a link to a how to that would be cool thanks
jslider is offline   Reply With Quote
Old 11-14-2007, 02:16 PM   #2
Trader Rating: 26 (96%+)
You would probly be better off saling your roller for $100 and then picking up a xxx-cr if you want to change the hubs and ect. Personaly I could care less about the hubs so I just run my mf1 w/ the new cr chasis, it is longer so the front wheels stay down better, lunsford turnbuckles, & ti pivot blocks. The chasis will improve traction & the rear shock tower will make the rear end more durable. The arms are actually very durable when you swipe a pipe & the stiffer arms will keep that nice agressive feal that the graphite offers. The one issue I had w/ the rear arms was that when I jumped they would break on landings and the softer shock towers help to abosrb the blows w/out anything breaking.
party_wagon is offline   Reply With Quote
Old 11-14-2007, 03:49 PM   #3
theanimaleide's Avatar
you would be better off just buying the cr, because to change it over, most of the parts are different composite, and it would cost alot
theanimaleide is offline   Reply With Quote
Old 11-14-2007, 08:20 PM   #4
well alrighty then that will just have to be the plan then , start saving money to buy 1
thanks for the input guys
