Old 05-29-2003, 09:18 PM   #1
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Default AE RC10T3 Forum...
Hey all,
This is a forum dedicated to the RC10T3. This is the place to post any questions, suggestions, etc. you have about the car.... I'll start..
DO they make a Slipper clutch for it?
LosiFromHell986 is offline   Reply With Quote
Old 05-29-2003, 10:17 PM   #2
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Of coarse there is a slipper clutch for the car, every T3 comes stock with it.
Old 05-30-2003, 06:51 PM   #3
really? I've never seen a slipper like that one, but then again, I've only had old cars, except my nitro 4tec, which was used, but I blew it up, got t ran over, ranaway into the curb
is the slipper set real tight? cuz I've broken two spurs in a week...
should I try setting it looser?
Old 05-30-2003, 07:49 PM   #4
Check your gear mesh to make sure it's right, then try loosening the slipper.
Old 05-31-2003, 12:19 PM   #5
xxxtracer32's Avatar
a broken spur gear is from gear mesh, take a pice of notebook paper and put it between the pinion and spur, move the pinon sug up to the spur and paper just tight enought not to break the paper, tighten the screws down and then spin the spur gear by hand to remove the paper and as long as the paper isnt torn or broken you should have the correct gear mesh.
as for the sliper you would want it to slip for one or two feet i belive on my losi i have it tight because i race stock.
xxxtracer32 is offline   Reply With Quote
Old 05-31-2003, 07:52 PM   #6
When I run stock motors, I do lock down the spur gear, or just run a lightweight locker, never stripped a spur gear on any one of my associated cars in years of racing...
Old 06-01-2003, 11:12 PM   #7
whats a "light weigtht locker"?
Old 06-01-2003, 11:21 PM   #8
Just a piece that bolts up to the spur gear, and locks down onto the shaft. Eliminates the entire slipper clutch and weighs 1/4 what the slipper would, cuts out on a lot of rotating mass.
Old 06-01-2003, 11:29 PM   #9
so your just taking away the slipper, thats not a locker, a locker is in the diff. when the axles are "locked" together meaning each wheel gets 100% of the power from the trany (aside from any loss from the slipper slipping). i dont think you would realy want to run a "locked" diff on a t3 that would just make its handling go out the window.
Why is this forum listed under the On Road Forum? sport10 Onroad Nitro Engine Zone 0 01-11-2007 08:06 AM
RC10T3 spesh R/C Items: For Sale/Trade 0 09-02-2006 09:29 PM
RC10t3 and hpi pro! davidjohnson88 R/C Items: For Sale/Trade 4 02-05-2005 10:40 PM
Wtb: Rc10t3 fishman156 R/C Items: Wanted to Buy 1 09-29-2002 11:36 AM
