Old 11-08-2007, 05:18 AM   #1
Default What is the best charger under US$200
I am getting a few 3 cell lipos.
I was thinking fo getting the associated Pulsar Competition 3 Charger
or the Max amps one specifically designed for lipos.
Which one is better?
I hear that 6 out of 10 world offroad champs use the LRP Pulsar.
george_georgoul is offline   Reply With Quote
Old 11-08-2007, 05:23 AM   #2
magm20001's Avatar
thats coz they are sponsored by LRP/Associated. they would of won with any charger.
you probably want the duratrac ice, great charger for lipos.
RIP Kanye West ..... Mom
magm20001 is offline   Reply With Quote
Old 11-08-2007, 05:35 AM   #3
Jake S's Avatar
Trader Rating: 66 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
order: checkpoint tc1030 (upgraded ice) -> lrp pulsar 3 (great small charger) -> duratrax ice (good if your looking for absolute cheapest)
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 11-08-2007, 05:45 AM   #4
Even though I do not own one, but the MRC Superbrain 989 for $139.99 at www.carolinasrc.com is the best deal that includes it's own power supply for that price.
It can charge li-pos and nickels batteries up to 10 amps along with and can break in motors, cycle charge, etc etc.
Originally Posted by MRC
SUPER BRAIN 989
Brand: MRC
Item # RB989
The Super Brain 989 “do-it-all” AC/DC charger will make short work of recharging & rejuvenating any battery pack from 1-8 cell lithium, 1-25 cell NiCd/NiMH & 6-24 volt lead acid and gel cell batteries. The Super Brain 989 has many new features and proprietary technology that makes it the new top choice for all RC drivers and pilots. From recreational hobbyists to pro-racers to seasoned flyers, the Super Brain 989 has it covered!
The Super Brain 989 has a genuine peak detect charge rate of 0.10 to 10 amps for NiCd and NiMH cells, and constant current/constant voltage of up to 1.2c max for charging lithium cells. There’s programmable battery cycling and conditioning, with selectable charge and discharge rate from 0.10 to 10 amps. That’s right, up to a “real” 10 amps! Temperature sensing & control too, with the included temperature probe. The Super Brain 989 is a complete AC/DC charger and comes with its own 10-amp power supply. MRC built in a 24-battery pack profile/memory feature & built-in safety confirmation to help put the correct charge in your different battery types. We included a motor break-in feature with adjustable time and output to make light work of conditioning your competition motors prior to installation.
The Super Brain 989 will accept everything from single cell glow igniters, receiver packs, transmitter packs, main power packs of all types and field packs for your starting and field equipment. Special booster circuits give you 1-30V output for bench testing and to power a comm lathe, tire truer, and portable bench tools too!
From Planes and boats, to nitro and electric radio control the new MRC Super Brain 989 Charger is simply the best of the best!
AC/DC Thermal Controlled & Fan Cooled Battery Charger, Including 10 Amp Fan Cooled AC Power Supply
Patented Micro Peak® Technology Included for NiCd & NiMH packs
Charges: 1 to 25 NiCd / NiMH Cells, 1 to 8 Cell Lithium, and 6-24 volt Lead Acid/Gel Cell Batteries
Cell Range of: 100-19,900 mAH
Charge Rate of: 0.1A up to 10.0A for NiCd / NiMH, and 1.2c max for Lithium Cells
Discharge Rate of: 0.1A up to 10.0A with Adjustable Cut-off Range
Adjustable Peak Sensitivity
24 Battery Profile/Memory Storage with Safety Confirmation (MRC SafeGuard™ Technology) & profile history recall
Auto Cycle Mode (1-9 cycles, 1-199 minute delay per cycle) For Battery Conditioning
Adjustable Trickle Charge Feature
Temperature Cutoff Range from 110°-160°F
Motor Break-in Feature with Adjustable Time & Output
1-30VDC 10A (120VA) Adjustable Output for Comm Lathe or Tire Cutter, etc
10A AC Power Supply, Temperature Probe, & Assorted Connectors Included
Resources to Download:
1.) RB989 ad - car
2.) RB989 ad - boat
3.) RB989 ad - flyer
4.) RB989 manual
5.) MRC Super Brain Charger Comparison Chart
What makes it a good deal is the power supply is included and not another $50+ add on!
Craps is offline   Reply With Quote
Old 11-08-2007, 06:33 AM   #5
Trader Rating: 26 (96%+)
Does it have an update for a123 cells? I also notice that the power suply is a 10 amp suply, can you charge at 10 amps w/ the stock power suply?
party_wagon is offline   Reply With Quote
Old 11-08-2007, 07:33 AM   #6
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
+1 I want to get rid of my Ice so I can get the Checkpoint charger .
Briguy is offline   Reply With Quote
Old 11-08-2007, 07:38 AM   #7
Regional Moderator
Exterminator's Avatar
With the Hyperion EOS1210i and two Hyperion LBA10 balancers you can charge 2 equal lipo batteries at the same time. And it also is ready for 123 cells. Nimh and nicads. It also can do 2C charge rate with the balancer. Just in case you need a fast boost. I believe this is the only charger that let's you see the individual voltage of each cell while charging.
Retired from sponsored racing, Now just having fun.
Exterminator is offline   Reply With Quote
Old 11-08-2007, 01:07 PM   #8
nyourgrill's Avatar
Checkpoint TC1030.
nyourgrill is offline   Reply With Quote
Old 11-08-2007, 01:15 PM   #9
Don't have any experience with the A123 stuff. The electric racers around here all use li-pos. With 8000 mah li-pos, no need to charge at 10 amps. just 8 amps which is 1C as recommended.
Old 11-08-2007, 01:19 PM   #10
KE4PJO's Avatar
For Li-Po only http://www.commonsenserc.com/product...roducts_id=185
KE4PJO is offline   Reply With Quote
Old 11-08-2007, 01:29 PM   #11
RBMike's Avatar
I have this and like it very much.
http://www.b-p-p.com/proddetail.php?prod=e_EOS_1210i
-EMBX6,T8 1400, RX8, 5S Lipo ,Elite-RC, RCM tray
-EMBX6,T8 1350, RX8, 5S Lipo ,Elite-RC, RCM tray
-B44 (Novak)
-ROAR 4 cell rule Blows
RBMike is offline   Reply With Quote
Old 11-08-2007, 01:30 PM   #12
Originally Posted by KE4PJO View Post
That is only a 2 amp charger that will take around 4 1/2 hours to charge a 8000 mah li-po compared to around 1 1/4 hour with a 8 amp charger.
Old 11-08-2007, 03:39 PM   #13
KE4PJO's Avatar
I don't know what you need 8k mah for, 3hr mains or something. Using a 4800 Orion and a 10.5, I seldom seem to use more than 12-1500Mah in a 6 minute run. He asked for the best under $200, in my opinion that's the best for "normal" use.
Old 11-08-2007, 03:45 PM   #14
Still with even a 4800 mah battery it will take 2 1/2 hours to fully charge with a 2 amp charger. 2 amps is too slow!
Alot of us use 8000 mah batteries in our T-4s with our 20 minute mains plus the 8000 is close to the same weight as a 6 cell nickel pack that most models were made for. The 8000 mah battery can be charged at an 8 amp rate so topping off that 1200 to 1500 mahs you used in that 4800 mah battery will be recharged almost twice as fast using the 8000 mah battery. We also use between 5.5 and 7.5 motors in our T-4s on 1/8th scale size tracks with 1/8th scale size jumps too!
Old 11-08-2007, 08:14 PM   #15
FrankW's Avatar
My Team Orion lipo says specifically not to use MRC chargers
I like my Astroflight 109. It can charge up to 9 cells at up to 8 amps.
-Frank
http://williams-luge.com
FrankW is offline   Reply With Quote
TD: RC18mt RTR, LRP Comp Charger, (2)GP4200 Matched for Lipo Charger/Battery...LOOK!! smarking1212 R/C Items: For Sale/Trade 7 10-08-2008 04:25 PM
FS: Duratrax ICE Charger, Great Planes Triton Charger, & MRC Power Supply wrxnfx R/C Items: For Sale/Trade 15 08-20-2008 11:33 AM
Mini-V, Lipo charger, Nimh/Nicd charger, Starter, AIRBOAT CustomTrendzInc R/C Items: For Sale/Trade 2 11-08-2007 03:08 PM
Duratrax IntelliPeak DC Only Mini Pulse Charger & Towerhobbies charger$25.00(Shipped) xsxracing R/C Items: For Sale/Trade 0 10-13-2007 03:51 PM
Integy 16x7v6 Charger (with 30 amp discharge), Tamiya F201, Astro Flight 109 Charger 403forbidden R/C Items: For Sale/Trade 4 05-07-2005 08:08 PM
