Old 11-07-2007, 09:26 AM   #1
Default Ball Diffs Vs Bevel Gears- Evader
I have an evader and no matter what I do
I always have problems with the diff.
All my nitro cars that are bevel gears are fine, never had a problem with diffs on nitro cars.
Are all ball diffs the same?
Is the evader a crap design?
Did I overtighten the slipper clutch and kill the diff?
george_georgoul is offline   Reply With Quote
Old 11-07-2007, 09:37 AM   #2
Trader Rating: 26 (96%+)
This is how I build my diffs and they seem to work amazing. First off, I pick up a can of white greese, comes like wd-40 but its made for heavey duty aps. Build the diff to standard specs, but for the thrust bearings I use the white grease, you can gob it on the thrust bearings too. Now, when you tighten the diff go and run through a tank of fuel at 1/4th throtle while holding one wheel, and then do the same for the other wheel. This will seat the balls in the diff. Next go and retighten the diff acording to the instructions. Now, go and find a way to lock the spur gear. You want to have the slipper slip and not the diff at all. You also want to spin the rear wheels and have the front of the car lifting up w/out anything slipping, but close to slipping. Now every so often check to make sure your slipper is slipping and not your diff.
party_wagon is offline   Reply With Quote
Old 11-07-2007, 09:48 AM   #3
badassrevo's Avatar
replace it with the diff from the new evader ext. it has a gear diff.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 11-07-2007, 09:52 AM   #4
What is the evader ext?
Is that a nitro?
Does it fit?
Old 11-07-2007, 09:58 AM   #5
badassrevo's Avatar
it is new, Duratrax just released a new evader it is electric.
http://www3.towerhobbies.com/cgi-bin...=LXSGU7**&P=ML
http://www3.towerhobbies.com/cgi-bin...?&I=LXSXA9&P=Z
Doug Lightcap
Old 11-07-2007, 10:05 AM   #6
Do you know if it fits in the evader BX?
Old 11-07-2007, 10:08 AM   #7
badassrevo's Avatar
it is supposed to, everything on the EXT is interchangeable. it is supposed to be more reliable lower cost version of the original.
Doug Lightcap
Old 11-07-2007, 10:35 AM   #8
Mate you are the best.
I cant thank you enough.
I just did not give up, i tried rebuliding the diff about 15 times, but still had problems.
metal spider diffs or ball diffs in mini inferno? JEFFRO503 Micro and Mini Scales 3 01-11-2008 11:48 AM
Kyosho Bevel Diff Gears sp1/sp2/777/7.5 tmaxxking R/C Items: For Sale/Trade 18 06-08-2007 04:11 PM
mini-t bevel gears DFroyd Electric Off-Road 1 09-28-2004 10:07 AM
Ball diffs versus gear diffs Cole Trickle Electric On-Road 20 05-16-2003 04:43 PM
Where to buy New Ntc3 Bevel and Ring Gears. Kool Nitro On-Road 2 04-02-2003 03:52 AM
