Old 10-26-2007, 03:34 PM   #1
Bare Bones's Avatar
Default A little confused about charging
Ok I have a 2 part question about batteries.
For example: Lets say the batteries are unmatched EP4200 mAh built side x side.
1.What is the best way to charge a new NiMH 6 cell battery for the first time.
I have read that a slow charge (400mAh for 12 to 14 hours) is the best.
I have also read that the slow, uncontrolled (non-peak sensing) charge will damage a Nimh cell if the charge is not stopped when the cell is full. The "theory" behind C/10charging is the rate is so low as to not harm cells once full. This is not true and it will damage them.
2. If its bad to slow charge a pack, how does one equalize the pack without a tray.
Bare Bones is offline   Reply With Quote
Old 10-26-2007, 05:01 PM   #2
annie_himself's Avatar
Send a message via AIM to annie_himself
I just cycle it 3 times. Let it cool for 5mins in between and mine are good to go.
annie_himself is offline   Reply With Quote
Old 10-26-2007, 05:38 PM   #3
foolio's Avatar
I would ask your battery provider what their charging recommendations are. If they are a reputable supplier, they should be able to tell you. If they can't, ask Trinity or someone else who sells the EP batteries. My guess is you probably just charge them normally. Like another poster said, maybe cycle them a couple times to get full power up before going racing. However, batteries are a big investment, I wouldn't listen to too many people here...not even me
foolio is offline   Reply With Quote
Old 10-26-2007, 05:54 PM   #4
johnnyboy's Avatar
Trader Rating: 28 (97%+)
After the pack is built, put about 2000MaH into the pack at 5 amps. Store or let cool. Discharge pack to 5.4V then equalize the cells to .90V. Charge then at 6amps with 3mV peak detection.
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 10-26-2007, 08:41 PM   #5
Bare Bones's Avatar
Thanks guys!! Much appreciated
Old 10-26-2007, 09:58 PM   #6
raceGEEK's Avatar
http://www.slingshotbatteries.com/ra...tructions.html
Here is a great article from slingshot about charging new batteries, it works quite well. Regardless of what your charging equalizing tray is a great thing to purchase if you don't already have one.
looking for xxxcr parts
xxxcr
xxx4
xx4
raceGEEK is offline   Reply With Quote
Old 10-27-2007, 12:06 AM   #7
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Default Megaflex
Any know what the benefit of megaflex charging is over normal charging? Im using a Orion Advantage charger.
Living the dream
www.chargersrc.com
dirtdustingdavo is offline   Reply With Quote
Old 10-27-2007, 12:35 AM   #8
johnnyboy's Avatar
Megaflex is only really needed for reviving older cells. I believe it just "burps" the cells to breakdown crystal or gas formations in the cells. I don't think anyone really uses it for modern cells anymore though.
Old 10-27-2007, 02:27 AM   #9
Rightio, ill keep using the spintec as it does the same thing more or less.
Living the dream
www.chargersrc.com
I'm New And Confused!!! shaunmotyka Nitro Off-Road 2 02-19-2008 03:03 PM
Confused kjkiller Monster Trucks 2 07-16-2006 09:37 AM
Im confused!!! Dirtfreak15 Rookie Zone 13 12-27-2004 09:41 PM
Confused Denso#1 Onroad Nitro Engine Zone 1 08-02-2004 12:26 PM
generally confused with charging Ooj Australian Racing 5 03-15-2004 05:13 AM
