Old 10-17-2007, 06:53 PM   #1
simba's Avatar
Default factory team b4 gearing ??
i have a ftb4, amd am using the 81 spur out of the box, and am using a 24 pinion gear, is this about right, what difference will it make going down to a 22 or up to a 26.
Team Associated Factory Team B4
Futaba 3PM 2.4GHz Spread Spectrum
Novak GTB Spread Spectrum ESC
Sponsored by Billowy-Power Batteries
PM me for the best priced ROAR approved lipo on the market
simba is offline   Reply With Quote
Old 10-17-2007, 06:58 PM   #2
mtn bkr's Avatar
Trader Rating: 17 (100%+)
How many turns is the motor you're using?
Ron M.
mtn bkr is offline   Reply With Quote
Old 10-17-2007, 07:03 PM   #3
simba's Avatar
im using a novak 13.5 brushless with a novak spread spektrum gtb esc
Old 10-17-2007, 07:17 PM   #4
mtn bkr's Avatar
Ah, okay. I haven't switched to brushless in my B4 yet, but I can tell you that going down from a 24 to a 22 will give you more punch and less top speed. Going from a 24 to a 26 would have the opposite effect. How does your car feel on the track? It should top out by the time it's 3/4 of the way down the straightaway. If it's still accelerating by the time you reach the end of the straight then I'd increase the pinion size. That's how it would be with a brushed motor, so I'm thinking the effect on a brushless would be the same. I think I remember seeing that you would gear a 13.5 a couple of teeth lower than you would a 27 turn brushed motor, so a 21-22 might be the way to go. Someone please correct me if I'm wrong.
Ron M.
Old 10-19-2007, 10:10 AM   #5
BuggyKing's Avatar
Baseline ur gearing at 25 pinion on an 81 spur then move up. Also check temp on ESC after running as well. Most guys I am hearing are running sometime all the way upto a 30 pinion.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 10-21-2007, 07:35 AM   #6
HEAT's Avatar
Trader Rating: 26 (100%+)
81 SPUR
21 PIN
WORKS GREAT @ MY HOME TRACK
HEAT is offline   Reply With Quote
Old 10-21-2007, 08:55 AM   #7
KustomRCGraphic's Avatar
Trader Rating: 33 (100%+)
With the novak brushless 13.5 in a B4FT with 81 spur we are using a 26 pinion and the buggy is super fast and have not had any temp problems. This in no an inside high bite small track with some big jumps and large straightaways, as well as outside loose clay tracks. Plenty of punch to clear jumps coming out of slow turns and outstanding straightaway speed.
Contact Larry G at [email protected] or check out my site at www.Kustomrcgraphics.net
KustomRCGraphic is offline   Reply With Quote
Old 10-21-2007, 09:01 AM   #8
MustGoFaster's Avatar
I found that with the brushless 13.5 motors they like higher tooth pinions.
For example, I started with 24T and when I went to 26T I noticed more punch and top speed.
It is important to check the motor temperature when you are testing new gearing to make sure that you are not going to burn up the motor.
MustGoFaster is offline   Reply With Quote
***Factory Sealed 12L4 Factory Team kit*** EZRC R/C Items: For Sale/Trade 0 11-05-2006 06:53 PM
FS: Factory Team NTC3 with Sirio Evo 2 World Champ Engine, K Factory, MX3-S Radio.. R3VoLuTiOn R/C Items: For Sale/Trade 11 09-23-2006 08:37 AM
what type of gearing on my team brood 19t marius Electric On-Road 12 09-23-2005 11:37 AM
factory team rc10t4 and factory team rc18t for sale Zac R R/C Items: For Sale/Trade 28 05-26-2005 05:42 AM
Gearing question for Team Associated T3 ThePrfctGetaway Electric Off-Road 3 03-18-2005 08:35 PM
