Old 10-29-2004, 03:13 PM   #511
Mugen9112's Avatar
Send a message via AIM to Mugen9112
Davidka- lol as much as i would like to take credit for that paintjob, i cant, my buddy (BODZ aka Doug Summers) painted that for me. in my opinion he is the best painter. you should check out his site, you will definetly be impressed!
http://members.fullnet.net/dsum/index.html
Mugen MBX6-T
Team Associated B4
Team Associated B44
Mugen9112 is offline   Reply With Quote
Old 10-29-2004, 06:56 PM   #512
warpig's Avatar
David... I run 2wd also.. you are right.. but in 4wd.. the acceleration is there regardless... it's more about control around corners and not making it twitchy due to moving the axis of the weight.. and having the tires further apart.. 4wd is weird compared to 2wd.. but you are correct.. the weight being behind or in front is just not as important in 1/8..
warpig is offline   Reply With Quote
Old 10-29-2004, 06:57 PM   #513
warpig's Avatar
doug is the best painter on the planet..
Old 10-29-2004, 07:14 PM   #514
Send a message via AIM to kreidel
So is it the short wheelbase when there is a spacer in the front and rear and or both inbehind the upright on the MBX5?
kreidel is offline   Reply With Quote
Old 10-29-2004, 07:23 PM   #515
Mugen9112's Avatar
Warpig- i dont think anyone can dispute Doug's skills
kreidel- short wheelbase is when both spacers are behind the hub. long is when both spacers are in front of the hub.
Mugen MBX6-T
Team Associated B4
Team Associated B44
Old 11-11-2004, 04:23 AM   #516
foampervert's Avatar
Send a message via MSN to foampervert
Default has anyone used the prospec?
hiya all mugeners!
i have a older mbx5 and am thinking of purchasing the new upper arm mounts, new lower arms and new rear upper arm links.
i believe it gives the front more caster and the rear more clearance.
has anyone used these mods or the prospec buggy and what are your thoughts abt them?
what kind of track condition do these mods favour? rough or smooth tracks?
thanks for looking in!
i appreciate your thoughts on this matter
-alexander
During heats, i use durex for both front and rear, with Hard inserts.
Sorex, i meant Sorex.
foampervert is online now   Reply With Quote
Old 11-11-2004, 08:02 AM   #517
Davidka's Avatar
Trader Rating: 77 (100%+)
The new rear upper links are supposed to allow for wheel clearance at max down travel. I've been using a set of Ofna dish wheels with the non-upgraded upper links and haven't needed to change it. I think the front end parts you're refering to are upper arms that sweep forward more. This causes a decrease in front caster which makes the car turn in more aggressively at the corner entry and they also allow for fine adjustment of caster throught the use of shims on the inner hinge pin.
Hope that helps.
Old 11-11-2004, 09:09 AM   #518
whats the difference between prolines crowd pleazer and crowd pleazer 2.0 body? Anyone tried these bodies? Someone said before here that crowd pleazer (old one) body touches the brake/throttle linkages, right?
penggoy is offline   Reply With Quote
Old 11-11-2004, 04:24 PM   #519
Davidka's Avatar
2.0 design is much lower "volume" makes the car much sleeker lookiing. There is a few good pic's on NEOBUGGY.NET of Chad Bradley's buggy with the new body.
Old 11-11-2004, 04:54 PM   #520
Default oh i see... thanks
hiya! thanks for your quick reply!
i thought the new arm was a front lower arm that is angled forward, and coupled with the new upper arm brace that allows a further 2 mm shift to the rear? should allow for more caster, innit?
or i could be wrong..hyuk
-alexander
and yeah, the new 2.0 body from proline does look pretty sleek on a mbx5, but looks just weird on a mp777... the nose is just HUGE ASS!
Old 11-11-2004, 06:22 PM   #521
Davidka's Avatar
You are probably right about the arm setup. I thought it was the other way around. I've got a stock MBX5 and I bought it from another guy that never finished it so I don't know if I have the latest arms or not. Seems to get around the track really well though.
Old 11-11-2004, 09:16 PM   #522
I found it thnx. But how come theres a hole on its right side window?
Chad's MBX5
Old 11-12-2004, 01:09 PM   #523
Mugen9112's Avatar
personally i prefer the stock mugen body................. proline ones break around the nose area to easily
Mugen MBX6-T
Team Associated B4
Team Associated B44
Old 11-12-2004, 02:28 PM   #524
Davidka's Avatar
The small hole is so the brake linkage doesn't touch inside the body. Mark Pavidis said that the body was going to re-tool slightly before release so I bet that is one of the small changes.
Mugen9112, are you refering to the original Crowdpleazer? That's good to know.
Old 11-12-2004, 03:04 PM   #525
JCathey's Avatar
Thumbs up
Hey what up dudes? I'm looking to get a MBX5 for my first 1/8th scale ride. What, if any, parts or mods are recommended for the car as it comes from the box? Any set-up tips to share? I can't wait to join the ranks of proud MBX5 owners!
JCathey is offline   Reply With Quote
FS Mugen MBX5-T Prospec & MBX5-R Both less than 3 gallons! V-Spec Less than 1 gallon! ffpm46 R/C Items: For Sale/Trade 20 08-01-2008 07:27 PM
whats the difference mbx5 prospec / mbx5 r lynell90 Nitro Off-Road 6 04-24-2008 03:31 PM
Mugen MBX5 Electric Conversion, MBX5 and MBX5R Spare Parts! Cain R/C Items: For Sale/Trade 18 04-10-2008 04:16 PM
Mugen MBX5, MBX5 Pro Spec, MBX5R Differences Cain Nitro Off-Road 12 10-01-2007 11:35 AM
MBX5 or MBX5 PROSPEC? Realworld differences? Jeel Electric Off-Road 5 12-05-2004 08:46 AM
