Old 06-08-2003, 09:45 PM   #16
SlobbaTech's Avatar
That rear end gives more traction/forward bite, coming out of turns, it isn't as good on bumps or ruts. So if Adams The Dirt setup doesn't get you traction and you're using same tires and foams as the fast guys and your track is smoooooth it might be worth it.
SlobbaTech is offline   Reply With Quote
Old 06-09-2003, 10:31 AM   #17
rod_b's Avatar
Send a message via AIM to rod_b
Why is it that the CVDs give better forward traction but the stock axles handle better? Everyone says this but its just not clear logically why it would matter.
rod_b is offline   Reply With Quote
Old 06-09-2003, 10:43 AM   #18
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Originally posted by jjmudd
Got a MT-12 just sitting on the shelf as back-up motor #2 for my NTC3. I'm trying one of the STS RS3's in the car now (for the price, it is smokin') and I have a M.S. Nova Mega in box ready for big races.
Cool, at least you already have the engines to expirament with. The only problem I can forsee, is that aluminum spacer that goes on the outside of the clutchbell, it's standard as well, so you gotta find something similar in 5mm.
Old 06-18-2003, 12:26 AM   #19
SlobbaTech's Avatar
Generally speaking whenever you make the rear end stiffer you will gain forward traction and lose sidebite. The CVD's pivot is made from steel and will bind up a lot more when under power. The Losi universals have a plastic yoke in them and do not bind up as much under load, that lets the suspension move easier and not feel as stiff making them handle each in their different ways on the track.
Old 07-01-2003, 08:49 PM   #20
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
I have the Sport NT. Really cool truck. I got rid of that rediculous diffnut holder and replaced it with a different nut of a larger size. The diff stay's nice and tight for several runs but I check on it occasionally if it loosened (which I doubt though..). I also have the M16 to use when the Mach .15 dies out. BTW this was taken at my sister's house in Greenwich, CT.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
FS: Team Losi XXXS G+ with parts!! Team Orion V2 Hitec 5625 cola R/C Items: For Sale/Trade 9 06-18-2008 08:11 PM
Team Losi 4 Piece Nut Driver Set and Team Losi 4 Piece hex set (Metric) (like new) CRFXXXT R/C Items: For Sale/Trade 12 04-09-2008 10:49 PM
I've just read on LosiBk2.com that Team Losi are not sending a team to the worlds. Mabuchi540 Electric Off-Road 170 09-18-2007 05:32 AM
TEAM LOSI XXXT ROLLING CHASSIS INCLUDES TEAM KINWALD MOTOR AND 5 GP 3300 CELLS pcr2nv R/C Items: For Sale/Trade 1 04-23-2006 08:58 PM
** Team Associated announces plans for acquisition of Team Losi: A & L Racing ** G-spec Electric On-Road 5 04-01-2004 03:02 PM
