Old 10-15-2007, 03:40 PM   #1
ERustler's Avatar
Send a message via AIM to ERustler
Default Semi-Janged Rustler with stripped spur
heres some pics of my 1/2 janged rustler, i put a 4200 MaH battery in it, and can you say WHEELIES ON DEMAND?? but about 4 minutes into the run, i stripped the spur, i think i need to lower gearing and loosen slipper more...? what are your thoughts?
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
There is no such thing as budget RC.
ERustler is offline   Reply With Quote
Old 10-15-2007, 03:52 PM   #2
sport10's Avatar
Stripped spur gears are usually the result of improper gear mesh or having the slipper too tight.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-15-2007, 04:19 PM   #3
Trader Rating: 16 (100%+)
+1 and I see no pictures.
kavvika is offline   Reply With Quote
Old 10-15-2007, 06:06 PM   #4
ERustler's Avatar
Cool
i think both and had to mess with camera...
now there up.
Semi-Janged Rustler with stripped spur-dusty-rusty.jpg   Semi-Janged Rustler with stripped spur-janged-battery-thing.jpg   Semi-Janged Rustler with stripped spur-mamba.jpg   Semi-Janged Rustler with stripped spur-janged-arm.jpg   Semi-Janged Rustler with stripped spur-stripped-spur.jpg
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-15-2007, 06:08 PM   #5
ERustler's Avatar
Thumbs up
it was good timing cause i was gonna gear down anyways, so i spent 6 bucks to buy a smaller pinion and another spur.
and i loosened up the slipper.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-15-2007, 06:12 PM   #6
jatoman1992's Avatar
Trader Rating: 4 (75%+)
Send a message via Yahoo to jatoman1992
dont u mean brushless system = wheelies on demand
Pre-mix:
Kawisaki KX125-bored out to a 134cc, VForce reed valves, FMF gold series pipe and shorty silencer, phathead racing cyl head w/ interchangeable domes, and wiseco flat to piston
Nitro:
Ofna Ultra LX Pro- Axial .28 1S w/ JP-2 Pipe, Hitec HS5645MG(steering) and Hitec HS625MG(Throttle/Brake)
Electric:
Losi Micro-T- stock
Coming soon: Associated FT B4- stock
Ofna LX Pro as a roller w/ extras- $150
Starter box(1/8 buggy) w/12V battery- $70
micro T- $50 OBO
Axial .28 1S- 6 gal. thru- $50 OBO
jatoman1992 is offline   Reply With Quote
Old 10-16-2007, 11:19 AM   #7
ERustler's Avatar
Cool
... maybe...
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-16-2007, 11:20 AM   #8
ERustler's Avatar
we'll see in a little bit when my battery charges.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-18-2007, 11:24 AM   #9
ERustler's Avatar
Wink
couldnt keep the front wheels on the ground!! this 4200 battery makes it FAAAST
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-18-2007, 11:30 AM   #10
ERustler's Avatar
i also lowered it about 1/2 of an inch and it seems to handle a little better, moved the shocks in the front, and moved the hubs in the back.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Old 10-18-2007, 04:46 PM   #11
kind of a newb here, but how would a stock geared vxl rusty on a 3s 5000 mah lipo stack up to that 7700?
jbinny is offline   Reply With Quote
Old 10-18-2007, 06:15 PM   #12
VXL>MM7700
I believe the 7700 motor has a 8-cell limit and top speed is really about 50mph, while the VXL can easily hit 65 with the proper gearing and a LiPo. Plus it will have much more torque and won't overheat. The 7700 motor is more for a light TC. Plus, from my experience, it does not cog at all, unlike my MM ESC. But you'll have to get past the cheezy case design.
Old 11-20-2007, 11:26 AM   #13
ERustler's Avatar
it does about 60 with the stock gearing and a 4200MaH NiMH battery, i could smoke a VXL if i had a LiPo.
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
Jammin Diff, w/ Lightened Spur And Extra Spur Gear prphze R/C Items: For Sale/Trade 0 10-07-2007 03:40 PM
Will standard spur gears fit an Assoc T3 or Traxxas Rustler? Help! rccardr Electric Off-Road 3 11-07-2006 07:06 PM
Question re Standard Spur gears: Fit Assoc T3 and/or Traxxas Rustler? rccardr Electric On-Road 1 10-25-2006 07:30 PM
F/S Tmaxx/ Nitro Rustler Steel spur gear John Bolten R/C Items: For Sale/Trade 7 11-29-2004 07:13 AM
Stripped Spur... Ares17 Singapore R/C Racers 9 02-10-2004 08:31 PM
