2-speed gearing
Old 10-15-2007, 08:47 AM
Default 2-speed gearing
How does it work on an electric vehicle? I mean, do they make them for electric vehicles? What are the positives and negatives of using one?
Thanks!
dustyz is offline
Old 10-15-2007, 08:50 AM
badassrevo's Avatar
here you go,
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWA:IT&ih=003
badassrevo is offline
Old 10-15-2007, 09:01 AM
Wow... interesting idear.
Why aren't they more common? I never even knew they existed.
What's the problem with them?
dustyz is offline
Old 10-15-2007, 12:29 PM
crazyjr's Avatar
The biggest problem, might be no brakes. It has to have a one way bearing, on the main shaft and second runs on a centrifugal clutch. So there would be no way to provide braking unless there is a provision to do it mechanical
crazyjr is offline
Old 10-15-2007, 12:36 PM
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Default nooooooooooooo
Beware!!!! Read the feedback that dude got for those 2speeds, its not good...i was thinking about getting that for an onroad car I have and went back into his feedback and it didnt seem good...check it out first.
trdsupra88 is offline
Old 10-15-2007, 03:17 PM
Thanks!
I think this was discussed a long time ago, but the bottom line is that a 2-speed is very unnecssary in an electric vehicle. Without going into much detail, a nitro engine can benefit from a 2-speed, since you can keep the engine in a rev range were torgue is maximized. On the other hand, an electric motor has maximum torque at low speed. Someone mentioned that a two-speed would probably increase wear on the typical r/c brushed motor, as there is a sudden spike in load upon shifting.
071crazy is offline
