brushless sensor wire wrap >
Old 10-14-2007, 10:05 PM
Dougg's Avatar
Default brushless sensor wire wrap
I use lrp, but I had to buy a novak 13.5 motor in a pinch. It didn't come with wrap for the sensor wire. I don't like the way that the wires are exposed. please help me find the part number for that wire wrap that the GTB/motor combo comes with.
Dougg is offline
Old 10-14-2007, 10:10 PM
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
It's just standard spiral wrap stuff...you can get it at an electronics place...or just call Novak and I'm sure they'll hook you up. If you get stuck for it, I have some here as well.
Turbo Joe is offline
Old 10-14-2007, 10:15 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I just used some wrap from Radio Shack it is black but it does the same as Novaks wrap.
BuggyKing is offline
Old 10-14-2007, 10:37 PM
Dougg's Avatar
Duh! Radio Shack... Thanks for the info guys.
Dougg is offline
Old 10-15-2007, 08:28 AM
Davidka's Avatar
Trader Rating: 81 (100%+)
I went to Radio Shack for this and the stuff I found was way too big. Any place that does car stereo installations will have the correct size though. You can make a good wire sheath with fuel tubing in a pinch too. Put a piece of music wire in a length of fuel tubing and use an exacto at an angle while you roll the tubing on a coutertop to cut through it in a spiral.
The plastic stuff is probably tougher.
Davidka is offline
Old 10-15-2007, 03:33 PM
encore75's Avatar
Trader Rating: 26 (100%+)
There's a guy selling some of the spiral wrap in this thread:
http://www.hobbytalk.com/bbs1/showpo...69&postcount=1
encore75 is offline
