Trinity CO27 Motor
If the batteries can push power through them, any Motor will work. The CO27 was designed for the higher capacity cells but I could get an 800mah receiver pack to turn a CO27. Go ahead with one, you'll be fine.
Get the biggest batteries you can find and use it....I use ib 4200's and the motor 'sings'. I've had a lot of 'stockie's' and the co27 has been for me the best !!!!
if you cant buy a good matched set of batteries look at buying loose cells that the matcher couldn't put a good pack together. for club it will work fine
www.teamhighvelocity.com has them for $4.00 per cell
