Old 10-08-2007, 03:39 PM   #1
simba's Avatar
Default gtb spread spektrum in a FT B4 ?????
i have purchased 1 of these gtb spread spektrum 2.4 ghz ESC's for my factory team b4 and was wandering where people using this have placed it in the chassis and how have they modified the body to fit it in, because it doesnt fit under the shell, it needs a hole cut in it, but then i want to re-cover it up, so looking for some ideas, someone must have the same set-up, show me some pics if your out there. Also what the hell is " schottky", it tells me i dont need this when using brushless. ???????
cheers
Team Associated Factory Team B4
Futaba 3PM 2.4GHz Spread Spectrum
Novak GTB Spread Spectrum ESC
Sponsored by Billowy-Power Batteries
PM me for the best priced ROAR approved lipo on the market
simba is offline   Reply With Quote
Old 10-08-2007, 03:44 PM   #2
air8's Avatar
In the B4/T4 thread people remove the fan and mount it on the chassis blowing across the ESC (airflow-front to back). Tape/glue/shoe goo. I don't run a fan with my 6.5. If I start thermalling sometime I might put the fan to blow across the ESC like I have seen pictures of in that thread.
--Driver...you are cleared into the track.....Smoke On.
--"U Ain't Fast!!"
Chris Pearce
air8 is offline   Reply With Quote
Old 10-08-2007, 04:07 PM   #3
B4Bandit's Avatar
Hey Simba. What motor are you running? As Air 8 put it, you might not need the fan at all...
B4Bandit is offline   Reply With Quote
Old 10-08-2007, 04:16 PM   #4
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I would suggest a fan. Even if you are not thermalling, it is always better to run at a lower temperature. It will increase the life of your GTB, increase efficiency, and there are just no negatives. I use the black Novak fan, mounted in front of the GTB and mount it with Shoe Goo/Automotive Goo. Also, when doing this, be sure to mount the GTB so the air can flow through the fins of the heatsink.
As for the Schottky, if you don't know what it is, then you probably aren't running one...
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 10-08-2007, 04:22 PM   #5
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
The Spread Spectrum ESCs run pretty cool, even without a fan...I wouldn't worry about it.
Turbo Joe is offline   Reply With Quote
Old 10-08-2007, 04:49 PM   #6
simba's Avatar
Default b4
im running the novak 13.5 brushless, it is the equivelant to the 27 turn stock motor apparently.
So is it just a case of unscrewing the fan and taking it off, maybe i could glue that to the chasis beside the esc and use it that way, would that be ok ????
Old 10-08-2007, 05:01 PM   #7
air8's Avatar
Yeah, That'd be ok. try to position the ESC so the fan is blowing air between the fins. I have the 13.5ss pro in my truck. A friend broke three blades on his fan in stock truck. I decided to take my fan off and use it when I got to mod buggy. But still don't use it there. The esc in my truck usually temps at 115-120 degrees when I temp it. The GTB is very tough and in the 104 degree building it never thermalled on me. But the fan will be extra insurance.
--"U Ain't Fast!!"
Chris Pearce
Old 10-08-2007, 05:08 PM   #8
simba's Avatar
Default B4
cheers mate
Old 10-08-2007, 06:10 PM   #9
AaronR's Avatar
Trader Rating: 111 (100%+)
Thumbs up
If you drive your B4 in a clean environment, it might be wise to pick up the JConcepts body with the raised sides/scoops and Dremel away the front face of the scoop to allow more air inside to cool the ESC. That way it has a cleaner look rather than a big hole in the top of your current body.
http://www.jconcepts.net/store/index...&products_id=4
AaronR is offline   Reply With Quote
Old 10-10-2007, 01:59 AM   #10
Here is another idea is to add scoops to any body with this from Blue Groove RC Concepts: http://www.bluegrooveconcepts.com/ca...oduct_id=29833
I am going to use this on my B44 body with the Novak GTB ESC.
Craps is offline   Reply With Quote
Old 10-10-2007, 10:51 AM   #11
air8's Avatar
That's pretty cool. But I'd end up with a ball of molten lexan at the end. LOL
--"U Ain't Fast!!"
Chris Pearce
Old 10-10-2007, 01:45 PM   #12
BuggyKing's Avatar
Trader Rating: 17 (100%+)
hey those scoops look real nice.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 10-10-2007, 05:36 PM   #13
I just ordered the scoop maker from Blue Groove RC Concepts to see if the GTB fan will fit in one of these scoops.
Old 10-11-2007, 12:02 AM   #14
simba's Avatar
Default gtb
hey craps let me know how you go
GTB Spread Spektrum LOSI SCOTT R/C Items: Wanted to Buy 1 07-27-2008 06:21 AM
LF 17.5 brushless GTB spread spektrum adamjrdad R/C Items: Wanted to Buy 0 03-04-2008 09:33 PM
N.I.P spread Spektrum GTB Stewart Fan R/C Items: For Sale/Trade 4 02-08-2008 11:33 PM
NOVAK SPREAD SPEKTRUM GTB sedanracer8 R/C Items: For Sale/Trade 4 02-07-2008 05:16 PM
GTB Spread Spektrum tomt2 Australia For Sale/Trade 7 10-09-2007 01:19 AM
