Old 10-03-2007, 09:19 AM   #1
Trader Rating: 26 (96%+)
Default What charger for orion lipos
I've seen where you can charge these cells at a 2x amp per ah rate. What charger can actually charge up a 4800 like this? I have heard that you need a charger setup to charge at the 2x rate instead of just charging it at a 9.6amp rate.
party_wagon is offline   Reply With Quote
Old 10-03-2007, 10:49 AM   #2
schmelme's Avatar
If everyone starts listening to what you "can do" lipo's are destined for the scrap barrel. Manufacturers recommend charge rates for a reason. I agree charging at 1.5c may be ok but doubling the manufacturer charge rate.I Dont think the guys next to or the hobbyshop owner will like that much.
Most mainstream chargers ice,checkpoint,orion,lrp are locked at 1c charge rate for a reason to keep people from testing the threshold of saftey. rant done
schmelme is offline   Reply With Quote
Old 10-03-2007, 10:57 AM   #3
kuzo's Avatar
Send a message via MSN to kuzo
In all fairness, Orion has stated that 2C charging is safe for their packs and is supposedly updating website and instructions to reflect that.
kuzo is offline   Reply With Quote
Old 10-03-2007, 11:15 AM   #4
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
http://rctech.net/forum/showpost.php...postcount=1606
Turbo Joe is offline   Reply With Quote
Old 10-03-2007, 12:19 PM   #5
So, what charger am I suposed to use to charge these at a 2c rate and will it charge at a true 2c rate or will a charger like the astroflight 109 still be faster just because it takes less time to peak the cells. I wouldn't really mind not having the packs peaked since the voltage is very linear and I would be running two of the packs in parallel so 9ah instad of 9.6ah wouldn't be much of an issue. Is charging them at a 2c rate w/ an astroflight 109 an issue or do you really need a special charger w/ an updated charging equation to charge them at a 2c rate as I have often times seen.
Old 10-03-2007, 12:48 PM   #6
Turbo Joe's Avatar
I use my ICE charger and I just tell it that the capacity is more than it is, then I turn down the "Max Capacity" to keep it from going over. On the Integy Lipo charger, you just crank it up. They all charge to a voltage first, so it really doesn't matter much.
I charge a little over 1C (usually 1.5), just to save a little time, because I run multiple classes. It doesn't save that much time, but it gets the battery sorta full a little faster.
Old 10-03-2007, 01:36 PM   #7
I recommend the Team Checkpoint TC1030 .. It's the upgraded ICE that can charge at 10 amps discharge at 30, and backlit all from factory
entilza is offline   Reply With Quote
Old 10-03-2007, 01:40 PM   #8
Turbo Joe's Avatar
It does have some neat upgrades, but an ICE can charge at 10 as it is...and you don't need to discharge Lipos.
Old 10-03-2007, 01:48 PM   #9
Trader Rating: 35 (100%+)
There are two really nice lithium only chargers that allow you to adjust to any current value you want up to 10A, FMA Direct Scorpion 2S and the FMA Direct Balancepro HD 6S. Both are balancing chargers, and have several features to avoid hurting lithium cells even when charged at 2C. The Balancepro is even more special because it can charge A123s too and at 10A. I have one and it works great. Go to www.fmadirect.com for more information. In my opinion, for the price, these are the best lithium chargers.
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 10-03-2007, 01:54 PM   #10
I forgot to mention, the scorpion 2S is about $70 and the balancepro hd is about $105. The only differences between the two is the balancepro can charge up to 6S and A123. They are both 10A lithium only balance chargers. The scorpion even has a pigtail adapter that fits orion cells perfectly. If you get the balancepro, you will have to make your adapter using the universal pigtail adapter.
Old 10-03-2007, 01:56 PM   #11
this is gonna be a really stupid question, so I apologize in advance.
what would the purpose of charging at 2c be? simply quicker charging time? will it change the punch of the battery?
Brew Crew Racing {Washington Chapter}
Home Track: Tacoma R/C Raceway
Associated B4, LRP Sphere Comp, 13.5 Novak/7.5 Novak (soon to be an X6)
Associated T4, LRP Sphere Comp, 13.5 Novak/7.5 Novak (X60 when it becomes available)
X-Factory X5, Novak GTB, 7.5 Novak (soon to be and X5^2)
Sponsor: My lovely wife Debi
Sweet Lou is offline   Reply With Quote
Old 10-03-2007, 01:58 PM   #12
Turbo Joe's Avatar
It just charges a little faster...not much faster, but a little faster.
Old 10-03-2007, 01:59 PM   #13
thank you.
Old 10-03-2007, 08:04 PM   #14
AndyMoore's Avatar
Trader Rating: 54 (100%+)
Send a message via AIM to AndyMoore
Why not just use the Advantage charger? They also offer a smaller version (in case pit space is an issue), from their Avionics line (the link below). Is charging at double the norm really that important?
Click Here
|JConcepts|Winning Edge Designs|
AndyMoore is offline   Reply With Quote
Old 10-03-2007, 10:08 PM   #15
From the sound of things i'll just stick w/ the astro flight. Charging at a 2c rate means it will charge to like 90% twice as fast. Once it hits 90% capacity all chargers will slow down. The astro flight 109 just peaks them faster then the ice does and I don't have experience with the check point. However I have heard that a few of the upper end chargers are even better then the astro flight.
Orion 3200 Lipos. Orion Charger, Orion balancer *new price* Mike Marshall R/C Items: For Sale/Trade 4 08-07-2008 09:26 AM
Orion Advantage Charger with 2 lipos orion/peak Rock Racing R/C Items: For Sale/Trade 1 04-21-2008 05:31 PM
spread spectrum gtb w/ 3.5r,orion 3200 lipos,ice charger and more nikkon R/C Items: For Sale/Trade 44 03-22-2008 10:04 AM
orion lipos w/ kokam scorpion charger party_wagon Electric Off-Road 0 06-05-2007 06:17 PM
nip orion advantage lipo charger and 2 nip peak carbon 3200 lipos bigl R/C Items: For Sale/Trade 15 04-30-2007 07:12 PM
