Best comm drops
Best comm drops
for those of you who like to get the best performance from everything, in your experience what are the best comm drops. Ive tried the trinity black death drops, they work well but the fact that their is no needle can make it a bit messy at times. also, i know many of these create allot of power right away, but what kind seems to last the longest into a run?
With that said, if you are running an on-road vehicle on a very high bite surface (ex. 1/12th scale or touring car w/ foam tires on carpet) then I have had really good luck with the REVTECH or REVTECH 2 drops from trinity. I believe that NIFTECH also has a good comm drop formula too, from what I can remember. Also, you can find the little plastic bottle with the needle applicator at most craft stores really cheap.
The best comm drop formula I have used so far is a brushless NOVAK motor! (J/K......Hope that helps some! Good Luck & Have Fun!!)
well im going to try to focus on stock 2wd and get away from 4wd for a bit, with mod i can get plenty of power, but stock i figured cant hurt to get the extra power up top. unfortunately most drops wont be able to do more than a laps. the question was more for curiosity any way, im really not a good enough driver to take advantage of ever little bit i can get.
