Old 09-21-2007, 03:55 PM   #16
Thanks again for the comments..
We have a very large outdoor track.
I may try 4 amps due to our outdoor track I could still use a bit of boost early.
I'm running a Kyosho RB5, 2wd buggy. The gearing imo is perfect at 21/78.
entilza is offline   Reply With Quote
Old 09-21-2007, 03:56 PM   #17
nc-hopsing's Avatar
I run EP4200's charged at 6 amps. I also run CO27 motors. Your gearing is about right. Check with Casper over at the Banzai motors thread or on the Kyosho RB5 thread to be sure though. He is a fast Kyosho/stock driver.
The key to running stock is carrying speed through the corners. I set my car up to have quite a bit of roll so that when I let off the "gas" the car will keep rolling through the corners. I also get rid of alot of drag brake. I find that it slows down the car too much when entering a corner.
Steve Butts
KYOSHO AMERICA.com -Peakmotors.com - kyoshoforum.com - Team SlantEyEs - Hardkore Paint - JBRL Off Road Series - JConcepts.net
nc-hopsing is offline   Reply With Quote
Old 09-21-2007, 03:59 PM   #18
nc-hopsing's Avatar
Thats a sweet track! Definately a track where you want to carry as much speed as possible through the those big sweeping turns. Good luck!
Steve Butts
Old 09-21-2007, 04:29 PM   #19
Dougg's Avatar
Sorry, hopsing hit the the most obvious point. No drag brake!! so true!! I accually have my throtal trim to ware if I don't hold the brakes on it will roll at about 4mph. Plus I drop my atv's on brake side to ware if I hit full brakes the rear wheels WONT lock up. I adjust my brake atv's for every round. As the track dries out I lower my atv's so my wheels wont lock up. Test and adjust before every run. Plus I thought you were on a small track, I don't know ware I got that from. Yes on a big track I would go for something in the same area of gearing you are. My track is only 60ftx30ft.
Doug
MBX7r, MBX7R Eco, 22-4 2.0
Dougg is offline   Reply With Quote
Old 09-21-2007, 04:35 PM   #20
nc-hopsing's Avatar
Exactly
Steve Butts
Old 09-27-2007, 07:35 PM   #21
I used to run alot of drag brake. no I dont run any, it really helps in stk.
Mitch P. is offline   Reply With Quote
Old 09-27-2007, 07:55 PM   #22
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
Send a message via AIM to chewiefttc4 Send a message via Yahoo to chewiefttc4
BACK when i was running stock i would step charge.. half at 4 amps and the last ten min crank it up.
charge at 4 amps and then two quals before yours.. crank it up to 6.5 or even seven.
had the punch througout the race and still made the race.
give it a whirl
chewiefttc4 is offline   Reply With Quote
Old 09-28-2007, 01:20 AM   #23
give it a whirl
im pretty sure that's not to great for your batteries.
Steve??.
Old 09-28-2007, 10:50 AM   #24
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Drag brake sucks....... you need that baby to coast. This fact should be a sticky for the noobs
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 09-28-2007, 11:47 AM   #25
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
I would run a larger spur. I believe an 81 would fit on the RB5? Maybe use an AE spur/slipper pads. Then go up 1 pinion to match. You will have more punch, and the same top speed and your motor will not run hotter.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is offline   Reply With Quote
Old 09-28-2007, 12:07 PM   #26
johnnyboy's Avatar
Trader Rating: 28 (97%+)
I thought the step charge was good for the GP cells, but not for IB cells?
"Almost Live Race Coverage": www.johnnyboy.ca
.:Team Orion : JConcepts : B-Fast RC:.
johnnyboy is offline   Reply With Quote
Old 09-28-2007, 12:28 PM   #27
Steve??.
never hurt my gp or ib cells..
didnt cause any premature loss or anything like that.
and not to mention the cells ran great. didnt get hot.
even though nimh produces its best current and voltage when they are a little warm.
Old 09-28-2007, 05:26 PM   #28
What about EP cells?
Old 10-02-2007, 01:55 PM   #29
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
If your motor is getting hot it's probably geared too high. Unless you have a crazy long straight at that track your gearing seems a little high to me for a truck. I like to keep motors under 150 so they don't fade at the end of the race, and a 6-minute race is going to get them pretty hot.
The CO27 motor has more torque than a Monster pro, so it can handle higher gearing. Lighter spring pressure will get you more RPM's but at the cost of torque. For off-road truck I always stick with the red pos, green neg for Monster Pros. For on-road I run lighter springs, like green/blue for smoother acceleration and more top end. Cut the comm every 5-10 runs for competition. Not optional.
3800 or 4200 packs shoud easily make 6 minutes with a stocker, we can get almost 11 minutes out of the 4200's running hard with a stock or 19T. Charge rates should be between 1 and 1.5C so if you run 3300's charge between 3.3 and 5 amps. 3800's between 3.8 and 5.7, 4200's between 4.2 and 6 amps. Anything over 6 amps seems to really shorten the battery life for very little gain. anything under 4 amps seems to take away punch. Whatever you decide, keep cycling your packs at the same rate and they'll perform more consistently. For longer run time, cycle your packs prior to race day by discharging to .9v/cell. Charging them in advance and re-peaking the pack immediately before the race will make a noticable difference in punch for your stock motors, plus it usually results in 3-500 extra MaH of energy in the pack.
EP cells - we tried them this year and they make sick power when they're new but seem to require a lot more individual cell balancing than IB's and they don't last as many cycles. I'll probably go back to the blue ones next year. I also don't care much for the 4200's, bring back the 3600 and 3800's they last forever!!
RC Dad is offline   Reply With Quote
Tamiya TA04 Stock Tips Pat Electric On-Road 17 09-21-2010 09:23 PM
Best Tips From Best Stock Racer- Clark Smith Zaner24 Electric On-Road 11 11-05-2007 09:25 PM
TIPS FOR STOCK MOTORS BEASTY200 Electric On-Road 1 01-21-2007 03:36 PM
stock motor tips ? cain921 Electric On-Road 32 10-21-2005 12:43 PM
NEW Stock Motor break-in tips... gcooper Electric On-Road 1 07-22-2004 03:59 AM
