Gearing starting point on T4 for Mamba Max 5700
I'm not for sure, I never found a satisfactory gearing for mine. I run from 14 to 20 and it still run hot, I did find that 14 did offer the best balance (160 Motor, 164 esc and 160 batteries) this was in 95*+ humid weather. I was also told that if the batteries didn't go over 70*ambient i was ok, but i didn't like it, they were 4400 NIMH's. I run a 4600 with 2s lipo's and am much happier with it, My temps on the motor are 170*, esc 120 and batteries were not even warm, this is with 23/84 gearing and i'm told than i may be undergeared (hot motor/cool esc=too low geared) so i am still looking for the best gear.
hey ,15 to 17 will likely be what you'll need. I run 16/87 and when the track is 80* it runs 155 to 160*,esc 125-135,if the track is 110to 120*(sandy track)the temps go up by that 40* difference in the track,so 195ish,esc still cooler at 150-160*. I'm still waiting on a 15 pinion to see temps when the track is super hot. Dan
Glad its working for you. I may have had a demaged motor, it never run good without heating up
I'm at 18 I think.... I'll check it and let ya know if it's different.
All I know for sure is that it's fun to watch the front wheels keep lifting in the air coming out of corners
Sometimes I get on it a bit too much on the front straight and stand it right back on the motor plate... that's not good
