Old 09-02-2007, 11:16 AM   #16
BlackedOutREVO's Avatar
Trader Rating: 67 (100%+)
Originally Posted by annie_himself View Post
Is that chassis longer than stock?
Yes it is!
It makes the CRT.5 10th scale trick size... It will wear pretty much any 10th scale truck body, but the guys that have theres made to there spec's have theres, and use jato body's, or more specific the CP
BlackedOutREVO is offline   Reply With Quote
Old 09-02-2007, 12:05 PM   #17
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Sign me up.......I'll take one......
Originally Posted by RC-Monster View Post
http://www.rc-monster.com/tempforum/...read.php?t=984
There is a "top-down" view of the prototype attached in the above link(attached the picture here as well). We have offered a direct-fit motor mount for the stock chassis for a few months as well. There are quite a few conversions already done - several threads and pictures on our forums.
RED-LINE M03 is offline   Reply With Quote
Old 09-02-2007, 12:59 PM   #18
Captain Harlock's Avatar
Does this mean I can't use the truck's standard body with Mike's extended chassis?
Captain Harlock is offline   Reply With Quote
Old 09-02-2007, 01:07 PM   #19
Stock CRT .5 body. I woud think not. You could pick up a J-Concepts body. I'm sure a T4 or MF2 body would fit.
http://www.jconcepts.net/shop/
ever see a 1/10th scale truggy??-t4%2520illuzion%2520left%2520-%2520640.jpg   ever see a 1/10th scale truggy??-t4%2520illuzion%2520right%25203%2520quarter%2520-640.jpg
Old 09-02-2007, 02:38 PM   #20
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
Send a message via MSN to Dasupacat1
Originally Posted by mfishel View Post
I don't get it. Also I see you run at Summit, and have a XXXCR and XXX4G+. Did you recently come down to Planet? If so congrats on clearing the triple. You're still the ONLY electric to do it!
Yeah I run at Summit. I haven't been to Planet. You might be talking about John Marshall. I know he was down there last weekend. I would like to run down there though some time this season.
Dasupacat1 is offline   Reply With Quote
Old 09-02-2007, 02:45 PM   #21
mfishel's Avatar
Yup it was Marshall. A good time to run here would be the end of this Month (http://www.rcracenet.com/upload/EVENT_1168.pdf). Should be a great race.
mfishel is offline   Reply With Quote
Old 09-02-2007, 10:25 PM   #22
Here is my Crt.5 - it's almost done. I am waiting for my antenna mount, and I still need to get a battery. I also need to drill some holes in the battery mount to lighten it up, put a little foam padding on it and put the velcro strap on it.
I have only raced 18th scale for the last couple years and don't have any batteries other than 2/3A size, so I borrowed a Tyco 7.2v sub C battery (yeah thats right - TYCO) from a buddy of mine just so I could set the MM and get the steering servo centered and setup. After getting everything set I said what the heck and tried to see if it had enough juice to even run the thing. I was expecting it to cog, but to my surprise - it never did. I actually took it out in the street and drove it until the battery dumped - and not one cog. Anyways, here are the pics. The last one show the "please don't hit my expensive - it will burn up if punctured" battery guard. It is bent 90 deg. and keys into the notch on the bottom of the battery plate. I don't plan on using it all the time, just when racing or bashing with bigger trucks.
dway100 is offline   Reply With Quote
Old 09-03-2007, 07:21 AM   #23
RC-Monster's Avatar
The stock body is pretty short. The real issue is the shocks - they are tucked up into the body, so simply re-creating the body mount holes isn't an option. The stock length crowd pleazer would otherwise look OK on the extended chassis. A 1/10 truck body will fit pretty well - rustler bodies, for example.
You crt.5 has overkill written all over it, Dave. The Plett motor and battery box are pretty extreme. Nice and compact conversion, though. Better overkill than underkill. What battery are you planning on using(asuming the TRyco pack was a temporary thing)?
Mike
RC-Monster
www.rc-monster.com
RC-Monster is offline   Reply With Quote
Old 09-03-2007, 07:21 AM   #24
LosiSpeedDemon's Avatar
i was just thinking of doing this to my XXX-4 G+ the other day now ive just gotta come up with plans...
Dalton "Crash" St. John
LosiSpeedDemon is offline   Reply With Quote
Old 09-03-2007, 07:52 AM   #25
Thanks Mike. I am planning on Maxamps 3S 5000mah packs, thats what the battery guard was made to fit around. With the foam padding on the battey plate, I should have about 3mm between the battery and the guard. I know it's all a little overkill, but this is going to be my only R/C for a while, so I wanted to do it right. The Tyco pack is just temporary - I just can't believe it even runs with it.
Old 09-04-2007, 10:56 AM   #26
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
The Academy Vehicle mentioned Dave posted pix of a conversion he did. Basically you would need to machine a chassis, top deck, and driveshaft if you want it to be true truck specs.
But, for a more truggy conversion, you pretty much just need the longer suspension parts or heck, get some RPM truck rims with a wide offset, they will bolt up to the buggy no problem as the hexes are sedan sized hexes.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 09-04-2007, 08:46 PM   #27
*Chrominator*'s Avatar
Trader Rating: 19 (100%+)
This Hot Bodies Truck http://www.hotbodiesonline.net/kit.p...=66501&lang=en is what was talked about in a Lipo/brushless conversion of a 1/10 4WD Truck, in this thread.
http://www.rctech.net/forum/showthread.php?t=173482
Hi my name is Mike, and I'm a Chromeholic, my wheels have been chrome free for over a year, thanks to everyone who made fun of them.
*Chrominator* is offline   Reply With Quote
Old 09-05-2007, 08:27 PM   #28
streetracer745's Avatar
Send a message via AIM to streetracer745
im makin one out of my tamiya dark impact. its comin pretty good so far. extreemely stable. and once i get a stronger motor and a longer chassis itll be sick. ill post some pics up when im done
streetracer745 is offline   Reply With Quote
Old 09-06-2007, 01:07 AM   #29
NJA82's Avatar
Trader Rating: 33 (100%+)
Send a message via MSN to NJA82
Does anybody have anymore information on that XXX4G+ conversion?
Im really keen to get into that, would be sick as.
NJA82 is offline   Reply With Quote
Old 09-08-2007, 10:03 AM   #30
crazyjr's Avatar
Anyone thought of a Schumacher GTRe? its a 1/8 on-road based off the GTR nitro truck. I did some checking and found out the arms are the same between them and about 100.00 worth of parts and you can convert it to an electric truck. Wheelbase wise, its the same as a GT2/T4 and its slightly narrower. It uses 14mm hexxes, But can be wsapped to 12mm traxxas style easily
crazyjr is offline   Reply With Quote
Nsram ISTC, KO-PROPO 12th scale servo, JR and Hitec 10th scale servos crabboy Australia For Sale/Trade 2 07-14-2008 03:23 AM
1/10th scale truggy party_wagon Electric Off-Road 7 02-01-2008 01:19 PM
HUGE LOT OF 10TH SCALE & 12TH SCALE PAN CAR PARTS RED-LINE M03 R/C Items: For Sale/Trade 11 10-12-2006 04:57 PM
RCMRC 2006 FEMCA ( 1/10th & 1/8th scale ) and IFMAR ( 1/10th ) Qualifying Races Danny Teh Malaysian R/C Racers 81 02-24-2006 07:21 AM
Trade 8th Scale Buggy \ For 10th Scale Touring heyman R/C Items: For Sale/Trade 14 04-15-2005 04:01 PM
