Old 08-30-2007, 07:43 PM   #1
Nitro Herb's Avatar
Default mamba or novak??
im running a b 4 buggy and have decided to go brushless , i dont bash it i use it for club racing only, right now im running a reedy 15 turn motor. im thinking of getting a novak 7.5 or 8.5 , or possibly a mamba 5700. just looking for some pros and cons on the two systems , gearing suggestions , and any info in general on switching to brushless
Nitro Herb is offline   Reply With Quote
Old 08-30-2007, 07:48 PM   #2
Trader Rating: 35 (100%+)
Be careful getting a mamba max system, it cogs and will adversely affect your racing. Believe me, I owned 2 in the past and tried everything I could to get it to work properly, and it never did.
For a B4, I suggest a Novak 6.5r and GTB system, you will love it
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 08-30-2007, 09:30 PM   #3
Bill Crawford's Avatar
I run the mamba 5700 in a truck you should go with the 4600 it you get one the 5700 will pull the wheels down the strait
Bill Crawford is offline   Reply With Quote
Old 08-30-2007, 10:00 PM   #4
action135's Avatar
i have never had trouble with the mamba system.
but i have never tried the gtb system because i am completely satisfied.
the mamba system is perfect for club racing.
action135 is offline   Reply With Quote
Old 08-30-2007, 11:49 PM   #5
BuggyKing's Avatar
Trader Rating: 17 (100%+)
I would point you more towards the Novak 7.5R for a B4. It is a good setup for 2 wheel drive.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 08-31-2007, 12:27 AM   #6
i think the novak is more 'predictable' and thus more controllable. I think more suitable for race and tuning.
I've found my mamba25 to cog and have 'turbo-lag' until I used very good high discharge lipos. Maybe it's got to do with the fact that it's sensorless. But if you still wanna go with sensorless brushless systems, just make sure your batteries pump out more amps than the motor requires. And maybe use a big capacitor.
Lplate is offline   Reply With Quote
Old 08-31-2007, 01:05 AM   #7
Z-Fire's Avatar
Send a message via MSN to Z-Fire
I have the SphereComp & GTB both are very smooth.
The Lrp7.5 or 7.5R will have more torque,speed and midrange than your 15T.
My 6.5 has to much power for indoor (BUT GREAT FOR BASHING!!!).
Sory I have not tried Mamba or any sensorless
all I can say is I've heard they're better for bashing.
Original RC10
E-Maxx ,E-Jato
T3
FT T4,Sphere Comp,13.5 ,17.5 ss pro
FT B4
Z-Fire is offline   Reply With Quote
Old 08-31-2007, 05:33 AM   #8
fhm555's Avatar
I've raced sensorless brushless in off road mini's for a couple of years and the trick is hot cells, proper setup of the esc, and gearing. Unless you are going to run high capacity lipo packs I'd go with one of the sensored rigs in 10th scale. We have local guys running both the novak and castle brushless systems with no problems in 10th 2wd, but they are all running 6 or 8 K 7.4V lipo packs.
fhm555 is offline   Reply With Quote
Old 08-31-2007, 06:50 AM   #9
Nitro Herb's Avatar
thanks for all of the response guys the only problem i can see is that alot of you guys running mamba are also running lipo batteries . the few tracks that i race at i have not made lipos legal YET lol. i run 3600 and 4200 nimh packs . im looking for a little more overall speed and power than my 15t reedy im running and i have to put new brushes in every week , thats getting old fast.
Old 08-31-2007, 07:31 AM   #10
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I've ran both. And can tell ya the Mamba is fast, but will drain the heck out of the battery pack. Which will tell ya its definitely putting the fire to the motor. They run hot and not very efficient. None the less lightning fast.
The Novak runs cooler and more efficient draining the battery less. Yet just as fast. The ability to run on lower voltage is what keeps them running cool I would guess, and makes the low end smoother and would be more appropriate for 2 wheel buggy. I would guess the 5800 to be the best motor for one. I sure have seen a lot of post out numbering that thought. It seems the 6.5 or 7.5 is the way to go.
Never the less I would stick with the Novak.
UN4RACING is offline   Reply With Quote
Old 08-31-2007, 08:03 AM   #11
Nitro Herb's Avatar
the novak speed control looks tall ,where are you buggy guys mounting them ? it looks like the body would hit it if you mount it in the chassis tub
Old 08-31-2007, 10:37 AM   #12
I ran 3300 in a 6min offroad truck main and had plenty left with the 5700, like the one person said gearing
Old 08-31-2007, 12:19 PM   #13
trdsupra88's Avatar
Trader Rating: 25 (100%+)
Send a message via Yahoo to trdsupra88
Default b
I run the 5700 with my B4 and it is great. I have it geared with 21/84 for a tight indoor light slipper and it is perfect...
I cut my own hair ☆
trdsupra88 is offline   Reply With Quote
Old 08-31-2007, 12:41 PM   #14
Trader Rating: 24 (100%+)
I run a MM 5700 in my xxx-4 with a maxamps 2s 4000mah. I am thinking of getting a MM 4600 just because the 5700 has a lot of room I don't use much, plus I am thinking if the 4600 extends my run time (?), then it might be easier to run a little longer (on the same battery) with the nitro vehicles I get mixed in with. But I would not say the 5700 is necessarily "too much" in the xxx4.
BobWoodhouse is offline   Reply With Quote
Old 08-31-2007, 01:14 PM   #15
Suspended
as far as i know most places only allow sensored brushless motors so if you are doing this to race go with novak or lrp unless your club just doesn't give a rats ass.
hated1racing is offline   Reply With Quote
mamba vs novak sparkplug1288j Electric Off-Road 27 11-29-2007 02:05 PM
Can Novak 4.5R run on Mamba Max chumanji Electric On-Road 4 04-03-2007 05:12 PM
mamba max VS. novak gtb Jaysun Electric On-Road 12 03-20-2007 07:46 PM
Novak vs. Mamba Max chumanji Electric On-Road 6 02-14-2007 03:07 PM
Mamba Max Vs Novak 4.5 horizon644 Electric On-Road 73 01-09-2007 01:47 AM
