Old 08-29-2007, 09:09 PM   #1
Trader Rating: 24 (100%+)
Default Brushless questions
hey guys late starter here with the brushless gig.
my question is if you have a LRP sphere comp or TC can you run orion brushless or novak brushless motors of all turns on that speedo?
vice versa with novak speedo with lrp, orion brushless motors of all turns?
only reason i am asking is that my lhs, told me that you cant run the lrp with a novak 13.5 with the sphere, because novak does something different with the motors. finding it odd that you couldnt, but no experience and dont want to blow up a 180speedo.
thanks guys.
vic0280 is offline   Reply With Quote
Old 08-29-2007, 09:54 PM   #2
thanks guys.
hmmm... I have a sphere by lrp and a 13.5 by novak. just switched to it on tuesday from my gtb. seemed to run just fine. I believe they are interchangable either way. the only way I know for certain, because I have done it, is the lrp will run novak motors though.
Brew Crew Racing {Washington Chapter}
Home Track: Tacoma R/C Raceway
Associated B4, LRP Sphere Comp, 13.5 Novak/7.5 Novak (soon to be an X6)
Associated T4, LRP Sphere Comp, 13.5 Novak/7.5 Novak (X60 when it becomes available)
X-Factory X5, Novak GTB, 7.5 Novak (soon to be and X5^2)
Sponsor: My lovely wife Debi
Sweet Lou is offline   Reply With Quote
Old 08-29-2007, 10:28 PM   #3
schmelme's Avatar
Novak,LRP, and Orion(peak) motors are all interchangeable. They will work with any sensored speed control from LRP-Novak. Hope this helps.
schmelme is offline   Reply With Quote
Old 08-29-2007, 11:42 PM   #4
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
i have ran my lrp with a 4300 ,13.5 then to a 10.5 all in the past year with the same speedcontrol. you should be fine
wd40prerunner is offline   Reply With Quote
Old 08-29-2007, 11:43 PM   #5
Another thing to note may be the Turn of the motor and the ESC's motor limit?
Lplate is offline   Reply With Quote
Old 08-30-2007, 07:31 PM   #6
thanks, thought it could be done.
Old 08-31-2007, 12:43 AM   #7
Z-Fire's Avatar
Send a message via MSN to Z-Fire
thanks guys.
I have a sphere comp with a 6.5
I just bought A GTB & two ss13.5's.
I ran ready 3star(6.5) with gtb it works the same as my sphere comp.
Then I put a 13.5 on each they also seem the same.
the comp handles BL over 4Turns , TC over 3 , gtb no limit.
all sensored items should work together.
the only thing I did notice is the sphere's brake is stronger......
....or the gtb is weaker however you look at it.
but I'm sure that can be changed in the settings.
Original RC10
E-Maxx ,E-Jato
T3
FT T4,Sphere Comp,13.5 ,17.5 ss pro
FT B4
Z-Fire is offline   Reply With Quote
2 Brushless Questions. viper15 Radio and Electronics 1 11-22-2007 11:56 AM
2 Brushless Questions viper15 Electric Off-Road 4 11-22-2007 10:57 AM
2 Brushless questions. viper15 Electric On-Road 1 11-22-2007 09:50 AM
Neo Brushless questions Dustin Howell Electric Off-Road 5 05-24-2006 01:26 PM
Brushless questions johnny_rotten Electric Off-Road 9 02-15-2006 10:06 AM
