Old 08-27-2007, 10:33 AM   #1
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
Default Gearing starting point on T4 for Mamba Max 5700
Looking for input on what you guys are starting with for gearing on a 5700 mamba unit in a T4? Also, what temps are you seeing.
Thanks!
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 08-28-2007, 09:17 AM   #2
crazyjr's Avatar
I'm not for sure, I never found a satisfactory gearing for mine. I run from 14 to 20 and it still run hot, I did find that 14 did offer the best balance (160 Motor, 164 esc and 160 batteries) this was in 95*+ humid weather. I was also told that if the batteries didn't go over 70*ambient i was ok, but i didn't like it, they were 4400 NIMH's. I run a 4600 with 2s lipo's and am much happier with it, My temps on the motor are 170*, esc 120 and batteries were not even warm, this is with 23/84 gearing and i'm told than i may be undergeared (hot motor/cool esc=too low geared) so i am still looking for the best gear.
crazyjr is offline   Reply With Quote
Old 08-28-2007, 09:36 AM   #3
Thanks!
hey ,15 to 17 will likely be what you'll need. I run 16/87 and when the track is 80* it runs 155 to 160*,esc 125-135,if the track is 110to 120*(sandy track)the temps go up by that 40* difference in the track,so 195ish,esc still cooler at 150-160*. I'm still waiting on a 15 pinion to see temps when the track is super hot. Dan
danimal1965 is offline   Reply With Quote
Old 08-28-2007, 10:52 AM   #4
Tech Legend
Cain's Avatar
Thanks for the info guys. I started with a17 tooth pinion. I am going to go 1 down and temp it again and see how it goes. It didn't feel bad and the temps didn't get that high as what you are reporting, I think 130ish on the motor max.
Old 08-28-2007, 02:28 PM   #5
crazyjr's Avatar
Glad its working for you. I may have had a demaged motor, it never run good without heating up
Old 09-04-2007, 07:25 AM   #6
glassdoctor's Avatar
I'm at 18 I think.... I'll check it and let ya know if it's different.
All I know for sure is that it's fun to watch the front wheels keep lifting in the air coming out of corners
Sometimes I get on it a bit too much on the front straight and stand it right back on the motor plate... that's not good
glassdoctor is offline   Reply With Quote
Old 09-04-2007, 09:26 AM   #7
Tech Legend
Cain's Avatar
highly recommend you contact Castle and get there help. They are great guys there.
What is best starting point for gearing? ktmusa Electric Off-Road 9 06-27-2008 08:00 AM
Mamba Max 5700 TexasBoy46 R/C Items: Wanted to Buy 0 07-26-2007 09:35 AM
Mamba 5700 Gearing? RoostAZ Electric Off-Road 3 05-20-2007 12:13 AM
Downtravel, what's a good starting point? Cole Trickle Electric On-Road 13 04-05-2004 10:19 AM
Good Gearing Starting Point omalley Electric On-Road 4 05-03-2003 07:29 AM
