NEED HELP GEARING MY STAMPEDE ! >
Old 08-26-2007, 07:07 PM
HEAT's Avatar
Trader Rating: 26 (100%+)
Default NEED HELP GEARING MY STAMPEDE !
I have a xl-5 stampede that i have taken the stock 550 motor out and replaced with a 19 mod motor , i run 4200 6 cell packs , stock speedo it has 86 tooth spur and 19 tooth pinion it runs great but gets " HOT " Can someone give me advice on gearing
HEAT is offline
Old 08-26-2007, 08:46 PM
dallasv8's Avatar
Talking
try going down to a 16 tooth pinion
i run a 9x1 checkpoint in mine with a 93 spur and either a 12 tooth pinion or i run a 91 spur with a 14 tooth pinion,depending on which one i put on after i clean it all
dallasv8 is offline
Old 08-27-2007, 05:23 AM
HEAT's Avatar
I will try that thanks !
HEAT is offline
