4wd Brushless Combination?
#16
One thing to keep in mind when comparing brushed to brushless....we compare the end result RPM, but not the torque. The 6.5 may be comparable to a 10~12 turn, but if you take the massive torque the brushless puts out, it is truly more comparable to a 8~9 turn....look at how many people gear the brushless motors very tall compared to a "comparable" brushed motor and you will see my logic.
#17
Location: old boy from 'the switch'. now live in Brisbane.
How about a mamba 7700kv
Guys, just wondering if a mamba 7700kv brushless would be suitable for use in off road buggies. Are these better suited to touring cars or would it suit a lrp sphere partnering in a buggy? Would it be comparable to a 12 t brushed for power?
#19
I think your on the verge of a great decision. The Sphere/Neo combo is very reliable. I'd go with the 2-star in a 4wd buggy. I had the 2-star in a XXX4 and it was perfect. I now have a 1-star in a 2wd truck. I don't think Novak and LRP rate their motors the same. The Novak 13.5 is similar to stock, while the LRP 1-star (13T) is much much faster than stock.
Whatever motor you choose, the Sphere is a better choice for a buggy. They run much cooler than the GTB. I've never needed a fan or capacitor on my Sphere.
#20
#21
Trader Rating: 23 (100%+)
Thanks all. The neo's do seem to be the go as they are made with off road in mind, not to mention my rookie skills. Also I saw a bj4 on youtube with a 7700kv mamba in it and that looked frightningly fast. The thing was drifting unbelievably, but the chassis must have been well balanced to cope with the raw power. Cheers, talk soon.
The biggest difference between the 2 is the NEO motors suck and overheat which causes all sorts of failures, including esc failure when the motor melts down. The Vector series motors seem to be better but haven't had great luck so I am going to try the Orion/Peak motors. The ESC has a thermal switch but the motor doesn't and in a 4wd it seems like cooling is your biggest problem. I will say however for the 2+ years of running brushless motors I would take cooling issues over working on motors all the time.
-James
