Old 08-20-2007, 05:09 PM   #1
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
Default Pulsar 3 lipo help....
I just got the LRP pulsar 3 and the Orion 4800 lipo pack. Can the pulsar 3 charge the 4800 because in the little booklet that the lipo came with said that it has 4 cells and the pulsar can only charge 1 to 3 cell lipo.it also said to set the charger to 2 cells and 7.4v for the lipo..... Please help Im lost!!!
wd40prerunner is offline   Reply With Quote
Old 08-20-2007, 05:15 PM   #2
Scottmisfits's Avatar
The team Orion pack you bought should say 7.4v 4800mAh. That's a 2 cell pack. LiPo's are 3.7 volt's per cell so you should be fine.
Scottmisfits is offline   Reply With Quote
Old 08-20-2007, 05:18 PM   #3
kuzo's Avatar
Send a message via MSN to kuzo
The orion lipo would be set on the 2 cell 7.4V setting. Whatever mentioned 4 cells must be describing the packs configuration of 2S2P. Which means 2 cells are in series, 2 are in parallel. How many cells there are in series is the only determining factor on charger settings.
kuzo is offline   Reply With Quote
Old 08-20-2007, 05:19 PM   #4
thanks i must have just read it wrong. what amps should i charge at? i have it at 3amps now should i charge it at a higher?
Old 08-20-2007, 05:36 PM   #5
kuzo's Avatar
The 4800 can be charged at 4.8 amps. Technically you can go higher but keep it simple for now. Most lipos can be charged max at their capacity. So 4800 mah = 4.8 amp.
Make very sure you are following the manuals setup for lipo to the letter. LRP does not have it online yet so I can't check. Make sure you are not set in the nimh or nicd charge mode. I am surprised that you were able to set it for 3 amp manually as most lipo capable chargers don't let you select it - you set battery capacity and the charger selects charge rate. That's why I say doublecheck everything.
Old 08-20-2007, 05:42 PM   #6
Orion says a charge rate of 4amps max for this pack.
Old 08-20-2007, 05:45 PM   #7
Both the Duratrax ICE and the Checkpoint charger have an adjustable charge rate for the LiPo batteries. I haven't expiremented with it but I know that I can charge higher than that with those chargers.
Old 08-20-2007, 05:47 PM   #8
it has user profiles and lipo is user profile 3. here are the setting.... charge current-3.0A charger lipo volts-07.4v discharge current-10A discharge voltage 5.6v. thats all the setting there is on the lipo profile.
Old 08-20-2007, 05:49 PM   #9
it took me 56min to charge the pack at 3amps and that was only 2600mah.....
Old 08-20-2007, 05:54 PM   #10
It will go until the pack is about 90% charged and then drop in voltage. You will still get the punch but not the full rutime. This is completley normal. It should take right around 1 hour to charge your pack at a 1c rating.
Old 08-20-2007, 06:57 PM   #11
kuzo's Avatar
It's actually 4.8A. Just about every lipo pack on the market recommends a 1C (1 time capacity) charge rate. Hence 4.8A for a 4800 pack like the platinum.
The Ice does not allow you to adjust the charge rate in lipo mode. It locks it to a 1C charge rate. The only way to get around this is to input a different capacity for the pack. Orion's MrBlack has stated in the Platinum and Carbon threads over in Elec Onroad that these packs are totally safe to charge at a 2C rate. Ice users (and most other lipo chargers) have been having to get around this by entering the pack capacity at double.
Old 08-20-2007, 07:12 PM   #12
DENNIS STORTI's Avatar
Trader Rating: 42 (94%+)
Send a message via AIM to DENNIS STORTI
DO NOT LET THE BATTERY DISCHARGE DOWN TO ANYTHING UNDER 6.0 VOLT EVER
it will ruin your pack
i use the checkpoint tc1030 an u can change the rate of charge but for the 4800 i would leave it at 4.8 an make sure it is a cc/cv capble charger or dont bother. when charging the pack it never goes over 8.40 volts an the charge amp drops down to almost nothing when it is done just be carefull charging with that until u are sure the cahrger is working in the proper way for lipo or you will ruin it the first time u mess up
DENNIS STORTI is offline   Reply With Quote
Old 08-20-2007, 10:05 PM   #13
Maybe newer ones coming out now say 4.8amps but the paperwork included with my Orion 4800 Lipo reccomends a charge rate of 4.0 amps.
I am very comfortable using lipo batteries as I fly planes and heli's as well.
Old 08-20-2007, 11:28 PM   #14
ya that what the paperwork that came with mine said.
Old 08-21-2007, 07:05 AM   #15
kuzo's Avatar
Someone must have typoed on the newer inserts.
*** LRP Pulsar 3 Lipo/NiMH/NiCd charger *** r126 R/C Items: For Sale/Trade 5 04-01-2008 01:05 PM
Pulsar, Pulsar 2, Novak Smarty Tray SE, Integy Discharger prodirt19 R/C Items: For Sale/Trade 13 01-22-2008 02:58 PM
Brushless esc w/ 10.5, ICE or Pulsar 3, and a 7.4 LIPO inman59 R/C Items: Wanted to Buy 0 11-27-2007 02:38 PM
can the pulsar 2's charge lipo packs? johnny boy Electric On-Road 2 05-31-2007 11:39 AM
lrp pulsar competition 2, lrp pulsar sport, turbocharger/matcher CHEAP billjacobs R/C Items: For Sale/Trade 6 08-21-2006 09:57 AM
