Old 08-22-2007, 04:31 PM   #16
What ESC are you using?
The LRP Quantum II has a weak BEC, and will cause this problem. I have an older model KO digital servo, and that servo will cause a regular crystal radio to glitch.
The cap fixes it. The spek should be ok for most situations. I run 75mhz synthesized in my 3PK and have no channel issues, everyon else is on 2.4 ghz now, so I have all of those free channels...
Bike racer is offline   Reply With Quote
Old 08-23-2007, 06:29 AM   #17
stickman310's Avatar
Send a message via MSN to stickman310
That kinda happened with me with me AM Radio. I Used to have atleast one person on the same freq as me each raceday and had to be careful during practice times, but then they all moved to spektrum etc. and now I have no problems except the glitching at certain areas of the track, which I think is because it's such a cheap radio.
And does the cap give you a longer range than you would normally have without it?
stickman310 is offline   Reply With Quote
Old 08-23-2007, 10:01 AM   #18
shy@klp.no's Avatar
Is it possible to use a larger antenna on the surface system? (transmitter) Would it help?
Life's too short to go slow! www.ymr.no
shy@klp.no is offline   Reply With Quote
Old 08-23-2007, 12:43 PM   #19
jabroni racing's Avatar
Trader Rating: 37 (100%+)
Send a message via Yahoo to jabroni racing
Exactly, same thing happend to me, added the cap and all was great.. didnt need it on my cyclone speedo, just the quantum 2
jabroni racing is offline   Reply With Quote
Old 08-30-2007, 06:58 AM   #20
Has anyone's not actually worked at all until you put the cap on? Mines not working and I have one of those LRP AI Reverse 15t limits.
Old 08-30-2007, 05:32 PM   #21
sport10's Avatar
Bingo, antenna length has everything to do with range. The shorter the antenna the less the range. This is probably why the spectrum pro had less range than the regular spectrum reciever. Double the length of the antenna and see if that improves things if range is a problem.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 08-30-2007, 06:09 PM   #22
mfishel's Avatar
There is another problem I have observed. It is called 'signal washout' or something like that. When your transmitter is very near to your receiver this problem can occur. It seems to be more prevalent with indoor situations.
You will notice small erratic behaviors with your servos, and the signal LED will wink at you. It is a result of the receiver seeming to get multiple inputs from multiple sources that are on the same frequency. It is caused by the signal bouncing off objects and returning at about the same time.
The fix is to simply move away from your car. When you are running it won't be a problem. It's one of those 'don't worry about it' situations.
Certain ESCs do seem to be a problem. Use the capacitor. It should be the solution. Also note that certain ESCs are completely incompatible with a Spektrum system. The sport brushless Novak is one I know of in particular (XBR).
A lot of the pro drivers don't use the 2.4 systems for reasons other than range. Some describe a noticeable delay in responses over crystal systems.
mfishel is offline   Reply With Quote
Old 08-30-2007, 07:03 PM   #23
fhm555's Avatar
I've run a brushless (aon 4900 and mamba 25 esc) mini inferno for a couple of years now with a spek equipped M8 and have had very little porblem. It worked real well for a while but then I started having to reset the binding a couple times a race day with an occasional bout of jittery steering servo. Once I figured out it had to do with arming the system with a low battery the problem went away. As long as I remember to not turn it on if the battery is low it works great. It also seems to work better with team scream IB1400 packs than it does with regular 1200 or 1400 sport packs.
fhm555 is offline   Reply With Quote
Spektrum Glitch problems overflow Radio and Electronics 4 05-20-2008 08:17 PM
spektrum glitch with burshless system straightaway Electric On-Road 4 09-12-2006 08:01 PM
Spektrum - GTB Glitch/shut down Takt Electric On-Road 13 03-22-2006 08:33 AM
GLITCH.. zax Electric On-Road 18 09-25-2005 09:51 AM
Glitch tkhoo Malaysian R/C Racers 6 08-21-2004 10:15 AM
