Old 08-15-2007, 07:54 PM   #1
tenpins77's Avatar
Send a message via AIM to tenpins77
Default Slippery When Wet
hello, i went to change the supr gear on my ft B4. I noticed that there is a spring that you i guess tighten when you put the spur gear on. How far do i have to compress the spring? Does it mattter? Does it do anything?
thanks,
any help would be much apprecieated?
Also, anyone know why With some of the higher end esc's, like my novak gtx, only have one positive wire that you have to bus off the positive battery and motor? I know my old duratrax intellispeed came with two wires for pos and neg?
tenpins77 is offline   Reply With Quote
Old 08-15-2007, 08:15 PM   #2
foolio's Avatar
thanks,
That spring is for compressing the slipper pads. The more you tighten it down, the less slippage and vice versa.
foolio is offline   Reply With Quote
Old 08-15-2007, 08:22 PM   #3
tenpins77's Avatar
why would u want slippage?
Old 08-15-2007, 08:27 PM   #4
BuggyKing's Avatar
Trader Rating: 17 (100%+)
the spring is there for the slipper adjustment. It crucial since the slipper will dictate your acceleration. When the slipper is properly adjusted it should pull the front up as it's slipping. The purpose of the slipper is to protect the diff.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 08-15-2007, 08:27 PM   #5
TLRacing
Frank Root's Avatar
Trader Rating: 25 (100%+)
If they is no give in the drive train, then things break..
also, on you ESC question, you just put + wire to the motor and add a split off the wire to the battery.
Frank Root -- TLR Project Manager
Twitter - @FrankRoot FB - facebook.com/FrankRootTLR
Team Losi Racing (TLR) - Team Orion - Spektrum - JConcepts - Horizon Hobby - Stick It 1 - Sticky Kicks - Bradley's Fine Line Designs - liverc.com - OCRC Raceway - Tuning Haus - Pacific Coast Hobbies - RIP
Frank Root is online now   Reply With Quote
Old 08-15-2007, 08:35 PM   #6
tenpins77's Avatar
Default okay
okay, so how do u know where to start adjusting it from?
Old 08-15-2007, 09:04 PM   #7
pirate60's Avatar
Trader Rating: 15 (100%+)
Rule of thumb: tighten the nut all the way down so that the spring is fully compressed. Then back it off two full turns. That is a pretty good starting point, adjust as the conditions dictate.
pirate60 is offline   Reply With Quote
Old 08-15-2007, 10:07 PM   #8
T. Mertz's Avatar
Send a message via AIM to T. Mertz
tenpins- Let me give you the step by step procedure to getting your diff and slipper set right. The first thing you need to do is make sure your diff is tight, the way you check that is by taking off the right tire, pop off the ball cup for the camber link, which should let you tighten the diff screw inside the diff outdrive with a 5/64 wrench. The screw should be on the right size of the diff, unless it was put on the left side. To tighten that diff screw, hold the other sides tire, and tighten the screw to the right all the way, then back it out about a half a turn or so. This should be a good starting point. Pop the ball cup back on the car, put the tire on. Take the cap off the gear cover and like pirate60 said tighten the nut down all the way down then back it off 2-3 turns. This should be a good starting point. Now put a charged battery in your b4, turn it on, and while holding both rear tires on the ground, hit full throttle for about a second. If you here the slipper slipping and the front tires dont lift off the ground like they should, keep tightening the slipper nut until the front tires lift off the ground a couple of inches. This is the best way to set your diff and slipper.
Hope this helps.
Tim Mertz
Team Orion/Team Young Gunz!/BIG Johnson Paints/Long Island Raceway & Hobby
T. Mertz is offline   Reply With Quote
Old 08-16-2007, 06:59 AM   #9
wd40prerunner's Avatar
Trader Rating: 8 (79%+)
Dang! now that was a reply. thanks i didnt ask the question but that was helpful.
wd40prerunner is offline   Reply With Quote
Old 08-16-2007, 02:09 PM   #10
mfishel's Avatar
Hope this helps.
the screw should be on the right side of the diff, unless it was put on the left side. That sounds funny.
Make sure it IS on the right side when you're behind the car. If it's on the left it will keep loosening up on you and eventually damage itself.
mfishel is offline   Reply With Quote
Old 08-16-2007, 08:59 PM   #11
T. Mertz's Avatar
Yeah i hope its on the right side too.....forgot to throw that in there. thanks.
Tim Mertz
Old 08-16-2007, 09:01 PM   #12
T. Mertz's Avatar
no problem
Tim Mertz
slippery as freestyles Nitro On-Road 9 06-15-2008 02:46 AM
B3 setup for slippery track noline Electric Off-Road 4 03-30-2008 06:29 PM
Slippery Dan = Great buyer! Turbo Joe Buyer/Seller dispute and Feedback discussion forum 0 02-23-2007 11:05 AM
racing on slippery floor makytc4 Electric On-Road 3 09-24-2006 12:25 PM
Slippery track, need setup help. MDL Australian Racing 10 08-23-2005 04:13 AM
