Old 08-14-2007, 09:13 PM   #1
loc
Default Rustler XL5 Not Running 100%
Hello,
I am new to the rc world. My new Traxxas Rustler XL5 is giving me hell. I thought is was my battery so I bought a new battery 3300NIMH. That did not help. So I bought a new charger. That did not help either. So I am running out of ideas. Sometimes it will go pretty well and sometimes it will not. I noticed that the reverse works great. I checked all factory settings, and reprogrammed the ESC. I am out of ideas. Help me please.
loc is offline   Reply With Quote
Old 08-14-2007, 09:39 PM   #2
Registered User
Dirtfreak15's Avatar
is your charger a peak charger?
it could be false peaking
telling you its done charging when it actualy false peaked usualy when the charger gets hot it may do that
at least my superbrain does it every once and a while.
other then that idk
Dirtfreak15 is offline   Reply With Quote
Old 08-14-2007, 10:13 PM   #3
loc
I just bought a new Duratraxx INtellipeak pulse charger. supposed to be a good charger I hope. Sometimes the truck runs ok. It seems to wind the motor up more in reverse. It also seems to glitch every now and then.
Old 08-14-2007, 10:27 PM   #4
Is your radio's throttle channel (channel 2) set in reverse mode? If I remember correctly, the traxxas TQ radios have a 70/30 switch on the throttle trigger, and if the ESC is set up with your throttle channel in reverse, it may be receiving more throttle input in reverse than in forward.
First, make sure the ESC is setup correctly. It should have come with a manual - read it over and try to reset the speed control to box stock settings.
spud2030 is offline   Reply With Quote
Old 08-14-2007, 11:03 PM   #5
UN4RACING's Avatar
Trader Rating: 22 (100%+)
Sounds like you need to true the motor and change the brushes.
Or just clean it real good with a com stick and some motor cleaner.
UN4RACING is offline   Reply With Quote
Old 08-14-2007, 11:47 PM   #6
loc
i have only ran around 20 packs through the car. will the brushes wear out that soon. Also what do you mean by True the motor. Also I reprogrammed the esc.
Old 09-13-2007, 11:26 AM   #7
ERustler's Avatar
Send a message via AIM to ERustler
Exclamation
dynamite vision peak 2 charger
peaks and charges ANYTHING in 20 minutes on the high setting.
only bad thing is it cant charge lipos, only nicd/nimh.
44.99
HPI Hellfire SS
Losi Mini LST2
Losi Mini Raminator
There is no such thing as budget RC.
ERustler is offline   Reply With Quote
the difference between the nitro rustler pro .15 rtr and new nitro rustler 2.5 rtr rustyvan Nitro Off-Road 2 07-23-2010 08:07 PM
Rustler MM 5700 or VXL Rustler??? RCRat Electric Off-Road 4 08-14-2008 04:03 AM
Rustler & Rustler VXL Transmission.. andy85 Electric Off-Road 3 06-13-2008 05:52 PM
what temp. should my rustler be running at? rustlermaniac10 Nitro Off-Road 3 08-06-2007 12:23 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
