Neat Wiring!
Old 08-09-2007, 05:54 PM
BuggyKing's Avatar
Trader Rating: 17 (100%+)
Neat Wiring!
Anyone have a better solution to neater wiring. I am still trying to work on mine.
Any ideas. Thx
[IMG][/IMG]
BuggyKing is offline
Old 08-09-2007, 06:15 PM
You could run the esc wire in the batt tray where it is supposed to go. I run my PT right in front of my receiver. Then I do not coil my wires up but bundle them up in shrink wrap and hide them behind the receiver. Your kinda stuck with the motor wires unless you wrapped them in flex loom, which can be had from mcmaster.com in many different colors.
And for jeep sakes get that car dirty. It an offroad car. My B4 has not looked like that since the day I bought it.
trashedmaxx is offline
Old 08-09-2007, 07:17 PM
RodneyB's Avatar
Here's my T4 with brushless. I use the astro-flight 3 pin connector for easy motor change out. I keep the radio wires and motor wires wrapped.
RodneyB is offline
Old 08-09-2007, 07:19 PM
T. Mertz's Avatar
xxxcrracer- the wiring looks nice and neat to me....i always run my esc wire under the battery in that wire slot.....but its all preference. nice buggy by the way....nothing like a nice fresh b4!!
T. Mertz is offline
Old 08-09-2007, 08:05 PM
K_King's Avatar
Trader Rating: 47 (100%+)
K_King is offline
Old 08-09-2007, 08:15 PM
Originally Posted by K_King View Post
Kevin your shit is always dialed.
looks good.
Mitch
Mitch P. is offline
Old 08-09-2007, 08:27 PM
BuggyKing's Avatar
RodneyB,
I like the way it looks. And yes I do spend alot of time cleaning and tuning
the car. I won't even race unless the car is perfect.
Old 08-09-2007, 08:28 PM
AzBobby's Avatar
all your cars look great to me. like four years ago during the Cactus Classic i was having alot of issues, glitching issues in like three different spots on the track. it was making me crazy. so i tracked down Charlie from Novak as that is all i run. what he suggested to me was DO NOT run the esc wire under the battery. after time it begins to get pinched from the battery when you land from jumps. when it does pinch it it causes a voltage spike and or a voltage loss, thus it would glitch for about a second and then go back to normal. at that time i was running Losi's so it was easy to wire it clean by running the wire under the top tray for the servo. but with the AE's which i now run, its just kinda up there. i dont run at the back of the battery as having it near the battery wires and motor wires could then again also cause similar issues. every since i followed these suggestions from Charlie i have never had another issue. maybe it will help you.
AzBobby is offline
Old 08-09-2007, 08:31 PM
kuzo's Avatar
I'm starting to feel like quite the slacker after seeing these pics. Nice, clean installs guys.
kuzo is offline
Old 08-09-2007, 08:32 PM
mfishel's Avatar
My suggestion on the B4/T4 cars, in order to keep the wire under the battery, would be to use the T2 foam pad on the chassis and cut it out where the wire slot is. Then put a piece of electrical tape over the wire once it's installed. Works for me.
mfishel is offline
Old 08-09-2007, 09:21 PM
D Hunt 3's Avatar
K_King- Is that little fan the Novak fan or something else? Thanks
D Hunt 3 is offline
Old 08-09-2007, 09:30 PM
K_King's Avatar
Yeah its this fan.
http://www.losipartshouse.com/servle...ing-Fan/Detail
I could actually shave the edge a tick to make it not rub the body, which it barely does, but I havent gotten around to it.
K_King is offline
Old 08-09-2007, 10:01 PM
jk racing's Avatar
Trader Rating: 20 (100%+)
This was happening to me @ the last JBRL race in my RB5. I rerouted it around the battery compartment (toward the rear) and everything has been peachy since then....that was using an LRP QC2, so it isnt car or brand specific.
jk racing is offline
BuggyKing's Avatar
K_King,
Did you have to wire up the black wiring yourself. I like that.
Old 08-09-2007, 10:04 PM
BuggyKing's Avatar
I have an issue running the wire harness under the battery tray. It pinched the harness causing it to smoke the negative wire. So I decided to wire around the battery and no issues yet.
