Old 08-09-2007, 01:45 PM   #1
Leyler's Avatar
Send a message via MSN to Leyler
Default is it normal? plz answer i need help!
my inferno can turn right ok, but its left turn is like twice the diameter of the right, ok maybe not that much but a lot and it is very annoying and has caused me to crash a few times, how can i fix it?
sig.
Wicked Racing!!!!! :O
http://rcgearing.com
Leyler is offline   Reply With Quote
Old 08-09-2007, 01:48 PM   #2
Check your servo , make sure it is centered properly,then check you radio settings ie epa and steering trim.
RON F is offline   Reply With Quote
Old 08-09-2007, 04:03 PM   #3
BuggyKing's Avatar
Trader Rating: 17 (100%+)
You also might have stripped the servo arm as well if you crashed it quite a bit.
Our government is a #$%$ joke, from the head jester on down
RIP Mike M
BuggyKing is offline   Reply With Quote
Old 08-09-2007, 05:59 PM   #4
MADMAN23's Avatar
Trader Rating: 27 (97%+)
Send a message via AIM to MADMAN23
did you check your radio yet?
catch me if you can....
WWW.RCFANATICS.NET
http://rcraracing.com/sitebuilder/images/FORUM/index.php
C&D R/C RACEWAY
Team Wicked Racing
MADMAN23 is offline   Reply With Quote
Old 08-09-2007, 06:52 PM   #5
Jerry23's Avatar
dont know how your inferno is setup but check the servo saver also.
www.JerryRoyJr.com
Thunder Tiger/Mikes Hobby Shop/GulfCoast Raceway/Amsoil/Pre-Paid Legal
Jerry23 is offline   Reply With Quote
Old 08-10-2007, 08:59 AM   #6
Leyler's Avatar
it isnt the trim, i tightened the servo saver a bit but i dont know how it helps, can someone tell me what it does ad what tighter or looser affects? im not sure if the servo is off centered if it is how can i fix it? also the arm is not stripped, all the radio settings are good.
sig.
Old 08-11-2007, 01:50 AM   #7
try centering your servo saver,,, first try neutralizing all settings on your transmitter,,, then try to center the servo saver while it is turned on this is to make sure that you will not accidentally rotate servo position while installing servo saver play close attention on the front wheels while doing this, they should'nt too much far off than looking forward,,, if this doesnt work,,, try checking your servo you might have broken gears,, two ways to check is you can try rotating it left to right right to left i'm sure you'd be able to tell if the gears are broken are not,,, another way is to open the servo just remove the four screws at the back it should pop open instantly.
imel24 is offline   Reply With Quote
What car to get and it's 4am and still not an answer in site :( Mabuchi540 Electric On-Road 31 05-30-2004 12:55 AM
need quick answer Mr-s413bt Electric On-Road 2 05-04-2004 05:03 PM
Please someone answer me......... rcracer123 Electric Off-Road 8 03-22-2003 04:29 PM
Need an answer, Please Help!! nitro or nothin Electric Off-Road 0 02-01-2003 10:54 PM
