Old 08-28-2007, 10:11 AM   #16
You 'probably' don't need to balance your batteries every charge, but if you have a balance charger (such as the Digital Balance Charger from Common Sense RC), it is just as easy to charge through the balance connector, so why not? If anything it will just help keep your batteries even healthier and extend their life.
Common Sense RC
Common Sense RC is offline   Reply With Quote
Old 08-28-2007, 11:02 AM   #17
padailey's Avatar
Originally Posted by trashedmaxx View Post
What balancer would work for the orion 4800's and a maxamps 4s pack?
About any balancer would do as long as they can handle 2S-4S lipos. The problem is finding/making different adapters for the two different balancing taps.
padailey is offline   Reply With Quote
Old 08-28-2007, 11:55 AM   #18
Suspended
Originally Posted by wd40prerunner View Post
how do you balance orion lipos if that dont have the taps?
go to the orion forums at their website. this has been discussed. you have to buy a few things to do it but there are instructions on how to modify and set it all up correctly.
hated1racing is offline   Reply With Quote
Old 08-28-2007, 02:30 PM   #19
crazyjr's Avatar
My balancers let me balance at charge amps (1c) so why not
crazyjr is offline   Reply With Quote
Old 08-29-2007, 08:36 AM   #20
sport10's Avatar
With the taps you really do not need to have a balancing charger. All you have to do is charge one cell at a time. The charger will cut the voltage at 8.4 for each cell in turn balancing the pack. Just make sure you have your charger set to charge 1S or you will ruin the pack and possiblily start a fire when doing this. The mAh setting should not change. The balancing charger will be faster though than this method but as stated eariler it does not have to be done every time.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 08-29-2007, 04:54 PM   #21
pdungadamo's Avatar
if your willing to waste 3hours of your weekend waiting for each cell to peak at 0.1volts, then go for it.
but for me i rather spend $30 (same cost as a set of tires) to buy a balancer and save me 3 hours of my time for something else.
pdungadamo is offline   Reply With Quote
Old 08-30-2007, 05:19 PM   #22
sport10's Avatar
It does not have to be done everytime. More like once a month so the extra time is not matter to me.
Associated B44
Associated B6
Associated TC7.1
Old 09-01-2007, 02:11 PM   #23
So based on most of your opinions here, I guess I can safely charge my 4400mah 2s Lipos at 1C at the track with my non-balancing fast charger...
and use my balancing charger (Common Sense/DN) at the end of the day to charge at a slower 2Amp max current at home?
Great! Then I wont have to replace my chargers yet.
Lplate is offline   Reply With Quote
Old 09-04-2007, 07:46 AM   #24
I charge my pack with 0.1v of inbalance and at the final each cell reach 4.2V at same time
and it take less time to charge it with no balancer
best balance it with hx8080 charger individual cell charger
ironxxx4 is offline   Reply With Quote
Old 09-04-2007, 10:52 AM   #25
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
I have a related question.
I got an MRC 989 charger that will do lipos, but what I don't understand is when you buy a seperate balancer, do you somehow hook in the charger to the balancer then the balance to the lipo? Or is the balance ran seperately?
Exactly how does all this work together?
Seriously thinking of going to a 1 battery lipo setup here in my stadium.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 09-04-2007, 02:22 PM   #26
if you take equinox it balance between charger and batterie
the blinky astro flight balance when you plug it seperately with or without charger
i like the balancer seperately because the cable for balancing is very small for large current
balance charging aspris Radio and Electronics 1 09-09-2008 05:51 PM
lipo balance rjs_13203 Electric Off-Road 6 06-11-2008 10:10 AM
To Balance or Not to Balance Lipo Packs while charging RED-LINE M03 Electric On-Road 14 10-24-2007 05:00 PM
LiPo Charge Balance / Non-balance bugnet Electric On-Road 2 09-12-2007 07:39 AM
2-4s Lipo balance charger on the cheap! charges Two 2s packs at once! GigaahX R/C Items: For Sale/Trade 2 05-26-2007 04:02 AM
